Mighty Diesel Visit - Mighty Diesel
Smarty SSR
Old Jun 7, 2011 | 09:58 AM
Mrs. Diesel Pap's Avatar
Site Sponsor - Mighty Diesel
Default Smarty SSR
Smarty SSR
for Dodge Cummins Turbodiesel 5.9L (2003 - 2007)
Fast guide to Smarty SSR special Features
● Race performance CaTCHER software inside
● More than 15 billions of possible tuning customizations
● Fastest download in the industry
● ABS tire height updates in just few seconds.
● Not traceable in the stock setting. Smarty leaves no footprint.
● Manual High Idle is enabled in all softwares
● Reads Diagnostic Trouble Codes in plain text.
● No tools required, no fuses to pull.
● USB built in for simple updates .
● Most complete keyboard in the industry.
● Reliable, it works off your OEM hardware.
● Programmable Speed Limiter from 25 to 250 mph
● RPM limiter up to 4200
● Power on Demand
Fast guide to Smarty SSR software levels:
No need for a PC. No need to know about binary code. No need
to spend countless hours on a complicated software.
No need to become a software engineer to fine tune your truck!
The SSR delivers the right combination of performance
parameters to fully customize your engine. No matter what
modifications you have done to it!
Whatever race and class you want to compete in, the SSR has
the answer!
How it works
The SSR provides just one base performance software that
takes care of all the limiting factors like the speed / RPM /
Torque & boost limiters. Then you will need to fine tune the
injection duration, injection timing & rail pressure to the truck's
needs. The three most critical performance parameters in a
Diesel engine!
In order to allow the complete customization of the performance
software to the particular engine's needs, the SSR provides 50
levels each for the following parameters:
1) Low Load injection Timing ( LLT )
2) High Load injection Timing ( HLT )
3) Low Load injection Duration ( LLD )
4) High Load injection duration ( HLD )
5) Low Load Rail Pressure ( LLRP )
6) High Load Rail Pressure ( HLRP )
All you need to do is to select the tuning parameters that match
your truck best, voilą.
Power on Demand
100 power levels selectable in just one second during the
driving!
It's easy: just type the preferred power level directly on Smarty
keyboard, from 00 to 99. That's all!
For security reason, the truck waits that the throttle is released
before applying the new power level.
No trace is left in the ECM!
I herby CLAIM that Smarty is the FIRST AND ONLY downloader
that does not erase any of the stored data in the ECM. Smarty
does NOT leave any electronic footprints in the ECM or any
other electronic module in the truck. Smarty does NOT set ANY
codes once the ECM is set back to stock. Smarty does NOT
need to have fuses pulled.
No matter what the competition claims , in one way or another
they're ALL detectable.
Smarty is NOT!
Yet, Smarty can not do one thing for you. Fix what others have
broken. Smarty can not restore a key on counter that another
downloader has erased . Smarty can not fix VIN# troubles
caused by other products. If your Check engine / ABS light is on
because another product has screwed your ECM, Smarty can
not fix it, the other guy HAS to...
ABS / Speedo recalibration
The tire height can be adjusted up to 44" in increments of 10
tenth of an inch in just a couple seconds. Of course, Smarty
needs to be VIN# locked to the truck in order to get into the ABS
adjustment section.
DTC Code reader
The name says it all.
You can read and erase codes. Codes are displayed also in
plain English. That's old news by now. Smarty S-03 was the first
one to provide that utility, others found the idea to be a good
one too.
( Smarty does erase ABS codes too but does not display them )
ECM update speed
Faster than anything else on the market! Again we've done our
homework on the protocol. Less than 5 minutes. Three times
faster than a Star-Scan diagnostic tool or competitor.
We have developed our own bootloader in order to not have to
pull fuses should an update become interrupted for any reason.
All you have to do is to turn the key off / key on Smarty does
everything else on it's own.
You can order: http://www.mightydiesel.com/store/product_info.php?cPath=143_205_61&products_id=1918
OR
Call 877-354-7008
Jmrobinson
Sep 13, 2015 09:46 PM
Jmrobinson
Sep 13, 2015 09:44 PM
Apr 20, 2015 07:40 PM
Oct 28, 2014 07:00 PM
