24 valve Cummins check engine light
Old Jun 7, 2011 | 09:24 AM
biplanebob's Avatar
Default 24 valve Cummins check engine light
I recently purchased a 1998 motor home with a 24 valve Cummins 5.9 (275Hp), Allison 6 speed, and Freightliner chassis.
I just installed a Banks ‘Power Pac’ system, turbo housing, intake piping, and ‘Ottomind’.
Now when additional power is required to climb a slight grade, or accelerating at slow speeds, the “check engine” light will come on. If I ease up on the throttle it will go out, and when I depress the throttle the transmission will down shift and accelerate OK, and the light will remain off.
What is it indicating when the light is on? I cannot find a list of things that will bring the light up.
There seems to be a slight reduction in available power when the light is on, but that is hard to tell as I have very little experience with this RV or RVs in general.
bob
Old Jun 9, 2011 | 04:08 AM
97cummins's Avatar
You should have a scanner hooked up to it to see what code pops up. Then that will give us something to help diagnose with.
Old Jun 9, 2011 | 10:10 AM
biged681985's Avatar
its sounds like it could be your lift pump. but like stated, u need to get it scanned and find out what it has stored.
Old Jun 11, 2011 | 09:57 AM
biplanebob's Avatar
Default good scanner?
Thanks
What is the best scanner for personal use??
bob
burndiesel
10
Feb 7, 2023 01:15 AM
Higgy
Jun 5, 2015 09:16 AM
gauge1325
May 3, 2015 01:33 PM
moneypitk5
Feb 12, 2015 11:01 AM
Rebel_redneck
Sep 29, 2014 11:05 AM
