91 f350 7.3 wont start
Old May 31, 2011 | 01:33 AM
johnnyford's Avatar
Default 91 f350 7.3 wont start
ok parked my 91 f350 for 3 months untill i had time to put a new flywheel on (automatic)put the flywheel on new batt&starter new plugs & alt got power to ip getting fuel butt it turn to slow and i check the ground sounds like engine haveing hard time turning ran fine when i parked it could it have air in line and can it make the engine hard to turn? and its killing my batteries
Old May 31, 2011 | 07:26 AM
DieselCrawler's Avatar
so you replaced the batts and starter. what do you cables look like? can you test restance threw them? also what type of starter did you get? is the the big heavy one or the lighter gear reduction one?
Old May 31, 2011 | 10:48 AM
Arizhnt's Avatar
What is the CCA rating on the batteries you installed? These require at least 850 CCA, more is better. I have 1250 CCA group 31's in mine right now.
Old May 31, 2011 | 12:39 PM
johnnyford's Avatar
i bought a direct drive starter from world wide automotive and wires look ok but i put my ground wire from starter to batt and still drags and i have 950 ccahow much fuel is suppose to com out the metal line cus its just drip drip drip......... but the gray hose has a lot of pressure ?
Old May 31, 2011 | 03:07 PM
witch metal line?
Old May 31, 2011 | 08:14 PM
johnnyford's Avatar
for the fuel there is on metal line on top of the injector and then there is a rubber hose that runs threw the injector the one on top (metal line) is only dripping fuel but the hose is pouring out. bought another new starter cus i thought i might have burnt the other out turning over good now but no start
now the intake is not sucking in
Last edited by johnnyford; May 31, 2011 at 08:14 PM. Reason: Automerged Doublepost
Old May 31, 2011 | 09:53 PM
metal line to injectors will only have a little bit come out of it. the rubber line is your return line. depending on where you unhooked the rubber line from, there will be lots of fuel coming out of it. now, with all the injector lines hooked up, and cranking, do you get any smoke out of the tail pipe?
Old Jun 1, 2011 | 02:25 AM
johnnyford's Avatar
no smoke but i can feel air coming out but intake is pushing air out with exhaust smell
Old Jun 1, 2011 | 06:41 AM
tail pipe clogged?
Old Jun 3, 2011 | 11:17 PM
farmerdude's Avatar
try ether, or gas raggin' it.If it fires with ether,you've got air in the system.bleed it off with the bleeder on the filter housing. those motors were bad about gettin air when they sit for a long time.
