Coolant Leak in front
Old May 30, 2011 | 01:54 PM
BigBird389's Avatar
Default Coolant Leak in front
2006 6.0 4x4. I had the oil cooler replaced and a EGR delete kit installed in the winter. It has had green slime in resevoir every since. The shop told me it was fine. But twice a month I clean all the fluid out and replace. Now there is a leak coming from the middle of the front of motor. Runs fine, no smoke or white paste anywhere. Just loosing coolant. Any ideas?
Thanks
Old May 31, 2011 | 12:35 AM
cummin_un_glued's Avatar
FormerVendor
sounds like its leaking from the egr bypass there is a really short hose that comes in the kit, probably leaking there
Old May 31, 2011 | 12:57 AM
H.R.D's Avatar
Head Gasket maybe....
Old Jun 3, 2011 | 06:07 PM
BigBird389's Avatar
Thanks Guys!! It turned out to be a water pump!
Old Jun 4, 2011 | 03:18 AM
FormerVendor
or that...
IHdude
Chevy/GMC Duramax 01-04 LB7
Jul 12, 2015 11:14 PM
throttleup22
May 2, 2015 02:04 PM
crayons
Mar 20, 2015 03:50 PM
Mike0885
Feb 28, 2015 03:16 PM
dieseldummy
6.2L & 6.5L Performance
Oct 1, 2014 07:51 AM
