33's on stock ride height
Old May 27, 2011 | 03:51 PM
sledhed17's Avatar
Default 33's on stock ride height
I got an 2005 chev 3500 stock ride height with 16's on it. Was wondering if I can get away with running 33's on it without a lift really want a set of nitto mud grapplers but the smallest ive seen them for on the internet is 33's. Thanks
Old Jun 8, 2011 | 04:16 PM
1AMatt's Avatar
Site Sponsor - 1aauto
You will probably need a leveling kit in the front to clear them.... or at least crank up the torsion bars. then you should have no problem
Old Jul 4, 2011 | 09:32 PM
CincinnatisMostWanted's Avatar
I believe they will rub if you have not adjusted the torsion bars. It shouldnt take much to get them to clear, just crank the torsion bars a little.
Old Jul 6, 2011 | 01:11 PM
FordDZLMan9191's Avatar
Just use the torsion bars to raise it up. It should give you enough room for 33s. I had an f-150 that I put 33s under and it was stock height and only had to adjust the bumper for them to not rub.
Old Jul 6, 2011 | 03:26 PM
1AMatt's Avatar
T bars will do it. It will ride slightly better with new leveling keys tho. Usually new keys are like 100 bucks
Jsully
Aug 31, 2015 07:55 PM
06dodgecummins
Jul 13, 2015 11:24 PM
wannadrag
May 25, 2015 03:07 PM
RobbyQ
Dec 9, 2014 02:48 PM
Dec 8, 2014 07:10 PM
