Temp Gauge
Old May 24, 2011 | 05:46 PM
Twebb833's Avatar
Default Temp Gauge
Ok i finally got some guages, i got a glow shift 3 in 1. Boost EGT and Temp. I have a 5 spd manual so what should i do with the temp guage?
Old May 24, 2011 | 06:05 PM
CSIPSD's Avatar
Oil temp or water temp...
Or you can still do tranny temp, would scare you to know how hot the manuals can get!
Old May 24, 2011 | 10:39 PM
Twebb833's Avatar
whats the easiest one?
Is there one that you can just screw into?
Old Jun 1, 2011 | 12:27 PM
Michael's Avatar
I'd do Oil Temp - the port on the HPOP reservoir (but only on an OBS) is 1/4" NPT, you can use an adapter bushing to put a temp sensor in that spot. If you tow a lot in hilly terrain it'll scare you to see how hot the oil gets! Presumably the oil spray on the underside of the pistons is what heats it up when you are running at very high cylinder temperatures.
Old Jun 4, 2011 | 08:47 PM
Seventhree's Avatar
I've got a snap on scanner, automatically tells me oil temp in Celsius. There might be a wire to tap into somewhere
Old Jun 27, 2011 | 09:11 PM
95-SimpsonOBS's Avatar
did you get the 60mm single gauge or the pillar pod diesel combo they sell? 2 guys who i know have manual SDs and they went with fuel pressure
JDurks2
16
Jun 7, 2015 08:57 PM
doodieroot
May 10, 2015 11:48 PM
MrCat4974
Mar 23, 2015 11:30 PM
99stackedpowerstroke
Feb 7, 2015 10:58 AM
mule97
Dec 12, 2014 05:05 AM
