Fuel Additive
Old May 21, 2011 | 09:04 AM
mr_GDR's Avatar
Default Fuel Additive
It seems to be every one I meet has there own idea about diesel additives.
here is what I have been told, I should use them to help keep the injectors clean.
because the diesel don't have the right stuff in it(I don't know what that stuff would be)
I was told by different guys to run 2-cycle oil, Lucas injector cleaner or ATF in every tank of fuel.
what is the benefit? what is the down fall?(if any)
I would appreciate any advice on whats the best to add or if not to add any thing.
Old May 21, 2011 | 12:29 PM
CountryGirl91's Avatar
Today's diesel is low in sulfur (ULSD: ultra low sulfur diesel)- sulfur is like the lubricant in diesel. 2-stroke oil pretty much puts that back in the diesel to lube it up and that's what I run after I saw this: http://www.johnfjensen.com/Diesel_fu...itive_test.pdf
Oh, don't use 2-stroke in the newer diesel's though!
Old May 22, 2011 | 05:43 AM
MarineOne's Avatar
I use TCW-3 rated 2 stroke in my '06 and it does help keep the chatter down. I also used it in my '03 and it did make a big difference with it.
Haven't used it in my '08 yet, I'm waiting on the emissions stuff to fail so I can have it replaced under warranty and then bring it home to delete it.
-Kris
Old May 23, 2011 | 03:25 PM
mr_GDR's Avatar
thanks every one, I will do as you do..
Old May 23, 2011 | 03:30 PM
RAW's Avatar
RAW
2-stoke and ATF won't clean, but will lubricate. Personally I prefer a product that does both, and only run Stanadyne Performance additive (blue label).
Old May 23, 2011 | 03:39 PM
mr_GDR's Avatar
I will run out the Lucas I have then try the Stanadyne Performance additive, I have a face book site I have been putting info on that I get here and there if any of you would like to share your info and pix of your trucks check it out at Dodge Cummins | Facebook
Dbleo351
Nov 20, 2016 09:34 AM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
That boy GK
10
Oct 28, 2014 01:45 PM
