Latest Automotive Industry News Discussion of all topics pertaining to future automobiles or all Fuels that move them - Gasoline, Diesel , Bio Diesel , E85 , Battery , Hybrids , Electric , Hydrogen Powered , Solar Panel ..
Video: Here's why the 2012 Camaro V6 makes 11 more horsepower
Old May 17, 2011 | 06:10 PM
Diesel Bombers's Avatar
Staff Reporter
Default Video: Here's why the 2012 Camaro V6 makes 11 more horsepower
2012 Chevrolet Camaro engine weight savings - Click above to watch the video after the jump
The 2012 Chevrolet Camaro will feature 323 horsepower, or 11 more ponies than the 2011 model. But General Motors engineers didn't accomplish this feat by adding direct injection or variable valve timing. In fact, the 2011 version of the 3.6-liter V6 already incorporated those high-tech engine components.
Instead, engineers were able to add extra power by allowing the high-tech mill to breathe better. To do this, intake airflow was improved by seven percent through extensive simulation and bench testing. As a result, power is up by 11 horsepower, while exhaust flow is improved by 10 percent.
Engineers also manged to remove an incredible 13 pounds from the 3.6-liter by integrating the exhaust manifolds into the aluminum cylinder head. This change meant that a pair of old-school iron manifolds, 12 bolts, a pair of gasket and heat shields with six more bolts were eliminated.
Beyond weight savings, these changes also eliminate the potential for gasket failure while fuel efficiency is improved. The 2012 Camaro 2LS model will now boast 30 miles per gallon on the highway, up from an also respectable 29 mpg from the 2011 model.
Hit the jump to watch a short video, which shows exactly how GM was able to shave 13 pounds off of an already reasonably light engine. Then you can stay to read over The General's press release.Continue reading Here's why the 2012 Camaro V6 makes 11 more horsepower
Here's why the 2012 Camaro V6 makes 11 more horsepower originally appeared on Autoblog on Tue, 17 May 2011 16:59:00 EST. Please see our terms for use of feeds.
More...
Old May 17, 2011 | 11:13 PM
LORDDiESEL's Avatar
wow! that's going to be a bitch to port.
But i can't believe GM came out with it first.
Makes headers obsolete
Old May 18, 2011 | 12:04 AM
2009RavenR1's Avatar
Impressive the new V6's are putting out far higher number than the V8's were just 6 years ago.
