99-03 7.3L Performance Discussion of 99-03 7.3 Liter Ford Powerstroke Turbo Diesels Related To Performance And Longevity
Next Mod for the Truck
Old May 17, 2011 | 02:06 PM
dbranson1's Avatar
Default Next Mod for the Truck
Well, all the Mods so far are listed in my Signature.
I'm wanting to get suggestions/advice on what I should do next. Most of you have been down this road before, some a FEW times. I am shooting for about 450 HP and wanting to maintain a reliable DD and Tow Rig, and occasionally make believers out of those that doubt the abilities of a Diesel Truck as far as performance and sheer A$$ kicking power. My trailer is a 35' Toyhauler when loaded is about 12,500 lbs.
I know that there are threads about doing Big Oil or not, or whether to use AC injectors or Hybrids, or Fuel Ret Systems etc. Keep in my mind I am building a little at a time and want to keep reliability and towing strong.
So what would be the next step in building?
Old May 17, 2011 | 02:17 PM
95powersmoker's Avatar
Here is the order I would go about it...
Intake (Done)
Exhaust (Done)
Gauges (Done)
Chip (Get some custom tunes on your chip)
Trans mods
Fuel system
Injectors (For your goal, some AC's with 100% nozzles will work...Or some small Hybrids)
Turbo (You already have the 38r, I would run that)
HPOP (Depending on if you need it or not, You can roll with the stock one on some small hybrids, The AC's will push it, Need to know what condition your pump is in)
Studs, springs, pushrods (Do em now for the extra insurance...)
I may have forgotten something....
Old May 17, 2011 | 02:19 PM
CSIPSD's Avatar
AC's with 100% would put you right at 400... Going to need a bit more for 450...
238/100 would make 450 pretty easy.
Old May 17, 2011 | 02:24 PM
There you go, straight from the horses mouth, Hybrids FTW!!
Old May 17, 2011 | 02:44 PM
dbranson1's Avatar
Is the DieselSite CPR Fuel system as good as it gets? Or are there others that are comparable?
Hybrids FTW? What does FTW mean?
Old May 17, 2011 | 04:10 PM
CSIPSD's Avatar
Dieselsites fuel system is very good, but I prefer Strictly Diesels (what I run).
Hybrids are a type of injector A core with B p&b...
FTW is For The Win
Old May 17, 2011 | 05:34 PM
dbranson1's Avatar
Ahh Thanks! I checked Strictly Diesel and they were out of the product, and DieselSites says they are 3-4 weeks out.
Do I read the Strictly Diesel right? Their product is a little less money?
Old May 17, 2011 | 05:47 PM
CSIPSD's Avatar
Depends on what your looking at. I have a full regulated return with the bowl delete... But Dieselsites comes with a pickup, pump and filters IIRC.
Just make sure your comparing apples to apples, not apples to cow dung... LOL
Old May 17, 2011 | 07:16 PM
dbranson1's Avatar
I'm totally confused at this point...You say have a "full regulated w/bowl delete", does that mean some systems aren't fully regulated?
I need a cheat sheet to understand abbreviations...IIRC?
So is it necessary to have a Hi Performance Fuel Pump when using an AirDog II and Regulated Return fuel system?
Old May 17, 2011 | 07:23 PM
CSIPSD's Avatar
You'll get them over time... LOL I still see some that I go WTF?
If I Recall Correctly
Here is a tank to motor kit...
Driven Diesel High Performance Fuel Delivery Kit
And here is the regulated return...
Driven Diesel 7.3L "Standard" Regulated Return Kit
And here is the same kit but with the fuel bowl deleted...
Driven Diesel 7.3L "Bowl Delete" Regulated Return Kit
Now if you delete the fuel bowl you have to add a filter set up under the truck, both a water seperator and a final filter. The factory system only filters to 12 micron, my prefilter/water seperator is a 10 micron, so I am already better then factory. My final filter post pump is a 2 micron... Not much getting thru.
Here is the Dieselsite kits...
http://www.dieselsite.com/index.asp?...ROD&ProdID=466
But you have to add the bowl delete to get a apples to apples...
Here is the Dieselsite "extream" fuel kit, which has the same fuel lab pump that Dennis has...
http://www.dieselsite.com/index.asp?...ROD&ProdID=467
I prefer Strictlydiesel kit because of the SS hard lines and the SS flex lines. I think they look better and perform better. I may be full of it, but I like his better.
Thats not saying Bobs is not a great kit, I just prefer the look of Dennis's kit.
