2003 Duramax Starting hard
Old May 16, 2011 | 05:24 AM
Fishman's Avatar
Default 2003 Duramax Starting hard
I am a 6.5 owner but told my buddy that I'd post a thread for him on the Duramax forum. His 6.6 is starting hard. He replaced glow plugs. I told him sounded like fuel bleeding back. Not sure. Any ideas? Thanks for any comments.
Old May 16, 2011 | 08:41 AM
turbostang7's Avatar
did he check the connector bars on the glowplugs, they go out often on the duramax. the fuel filter housing also develops leaks that a set of o-rings usually fixes which causes it to get air into the system unless the filter head is cracked. those are the usual causes. i noticed too when mine had questionable batteries in it it would crank ok but had a harder time starting, once i put new batteries in no problems.
Old Jul 31, 2011 | 10:40 AM
kdafire's Avatar
I had a time with mine this past winter not wanting to start at all. The shop i took it to told me that I had a bad battery cable and that it was not getting enough amps to turn the motor over fast enough to start it.
Old Jul 31, 2011 | 06:55 PM
PHPDiesel's Avatar
Sponsor
There are many things that can cause hard starts on these trucks.
Air entering the fuel filter housing from the bleed screw, improper fuel (low specific gravity, etc.) or any number of problems with glow plugs or compression (but those are usually accompanied by unburned fuel smoke and are more prone to occur in the late Fall, Winter, or early Spring).
The most expensive COMMON problem is high return rates on the injectors. If the high pressure pump can't develop >4500 PSI during cranking, the truck will crank and crank and crank until either the pressure is made or the batteries die. The slower the engine turns, the lower the pressure.
Old Aug 8, 2011 | 10:06 PM
MrHorsepower's Avatar
I had a similar problem. When cold it seemed to take longer and longer to start. Once hot it would be crazy long. Turned out to be a faulty FPR (fuel pressure regulator). Like a 200 dollar part. I used a OTC Genisis computer to read the rail pressure. I figured it was either pump or regulator so I went with the cheapest option and it worked. Before spending the cash do the simple stuff first. Look for fuel leaks when you pressurize the fuel tank. My brother's d-max had a fuel line leak between the filter head and pump.
Good luck
Oh yeah, don't go crazy pressurizing the tank. We only used 5 psi and a gas cap with a valvestem in it.
Last edited by MrHorsepower; Aug 8, 2011 at 10:06 PM. Reason: Automerged Doublepost
Old Aug 9, 2011 | 01:03 PM
PHPDiesel's Avatar
Sponsor
Good luck
Where in the world did you get a regulator for $200? GM list is $368.
Old Aug 10, 2011 | 08:33 PM
From Merchan Automotive - $193.00
Duramax LB7 Fuel Pressure Regulator
Old Aug 13, 2011 | 01:11 PM
2500HeavyDuty's Avatar
last time i had hard starts and it was not electrial related i had bad injectors that were leaking fuel into my oil. check the oil for any scent of diesel to make sure.
but first thigns to check would be batteries and grounds and connections for corrosion.
Bamafantrey
Aug 24, 2015 09:30 AM
Easton18t
Jul 30, 2015 02:06 PM
joker55
May 15, 2015 10:24 AM
gwmeyer
May 14, 2015 12:46 PM
91 7three
Jan 7, 2015 09:37 AM
