Idle Solenoid Problem
Old May 12, 2011 | 01:36 PM
Chalob's Avatar
Question Idle Solenoid Problem
I have a 1986 F-250 6.9L that is having idle issues. I was driving it when it started revving up and wouldn't drop down to a regular idle. It was revving up so high that in fourth gear it would start to shake. I thought the problem was a bad Idle Solenoid so i bought a used one from Ebay and today put it on. However it is having the exact same issues as before where when you rev it up it will stay at a elevated idle and it doesn't matter if the electrical connection on the solenoid is connected or not. Any help would be much appreciated as I'm new to diesel vehicles.
Old May 12, 2011 | 04:08 PM
DieselCrawler's Avatar
unhook your thottle cable from the injection pump and see if it binds. they normally break the plastic guide near the injection pump and get hung up.
Old May 12, 2011 | 06:28 PM
vasmi's Avatar
Default Re: Idle Solenoid Problem
If its the idle solenoid u can disconect
Sent from my HTC Vision using Tapatalk
Old May 13, 2011 | 11:47 AM
Chalob's Avatar
Its not the throttle cable. The problem is when you give it gas it will stay at a higher rev for a couple seconds and then drop back down to a regular. And im just tapping the accelerator. Also it does this with the idle solenoid connected and disconnected, it dosnt matter. If the idle solenoid is connected the little piston on it will not push back in all the way by itself. You can manually push it back in but as soon as you give it gas again it pushes out and wont come back all the way.
Old May 15, 2011 | 11:12 PM
Chalob's Avatar
Alright i think i found the problem. There is a Temperature Switch that sends power to the Idle Solenoid when your engine is cold. Sometimes the Switch gets messed up and will continuously send power causing the idle problem i have been having. Going to pick one up tomorrow and try it, well see what happens.
Old May 17, 2011 | 12:16 PM
Chalob's Avatar
Not a lot of luck with the temperature switch. Kinda stumped at the moment. Herd also could possibly be the injector pump, but out of cash right now so the truck will have to wait.
Old May 17, 2011 | 07:27 PM
Sandman8105's Avatar
Had the same problem with mine. Look at where the cable is attached to the gas pedel. See if it sticks when you press it. My mechanic replaced the throttle cable and all is fine now.
Old May 18, 2011 | 01:49 AM
agent_123_2000's Avatar
like crawler said man, that too is where mine went bad, plastic inside the spring at the ip end of the cable,
burndiesel
10
Feb 7, 2023 01:15 AM
xbreaselx814
Dec 7, 2014 06:59 AM
hunt4beer
Nov 15, 2014 09:06 AM
JMC23
5.9L 24V Performance
Oct 28, 2014 11:03 PM
nevadagramm
Oct 17, 2014 07:59 PM
