questionable power
Old May 11, 2011 | 05:57 PM
BVFD54's Avatar
Default questionable power
I am probably showing my lack of knowledge on the IDI engines but I was wondering if my truck is lacking power. It seems to me that it should be able to pull a 3k lb trailer and a 7k lb skid steer fairly easy..... There is no black smoke and the pyro in the downpipe was running just below 900 deg pulling hills with petal on floor and not very fast at all about 25 mph. It has new injectors. It is factory turbo charged and was running 9 lb of boost on the hills. The truck also has the 3 in exhaust housing and a 3 in downpipe and is straight piped. It also has a k&n air filter that is clean. Possible injection pump that needs rebuilt?
The pyro is located just behind the turbo in the downpipe if you want to know....
Old May 11, 2011 | 08:56 PM
DieselCrawler's Avatar
everything seems to be right with what u said by the gauges. pyro being in the DP will drop it by 300 or so. so at the manifold u are around 1200. which is all u want.
i am going to take a wild guess and say it is an automatic. thats where some of your power is going. also depends on your gears.
Old May 12, 2011 | 11:21 PM
BVFD54's Avatar
it is an automatic. it is also at the stock setting on the injection pump as of right now. Should I move the pyro to the manifold for better readings?
Old May 13, 2011 | 12:04 AM
95powersmoker's Avatar
You will have more accurate readings there... Certainly increase your chance of preventing a meltdown...
Something definitely seems wrong if you were pedal to the metal and only going 25mph...
Old May 13, 2011 | 12:09 AM
BVFD54's Avatar
ill move the pyro then and see what the readings are. If there is a power loss here what would be the most likely culprit? Is there also any other ways that I could lower the EGTs if they are actually that high in order to run more fuel?
Old May 13, 2011 | 07:43 AM
Hummin Cummins's Avatar
My 85 6.9 diesle will pull a skidder on a trailer 65 mph with no turbo. I think if your running 9 psi of boost your problem is in your tranny do you have a temp gauge on that?
Old May 14, 2011 | 10:46 AM
BVFD54's Avatar
no temp gauge on the tranny... im gonna pull the rearend part this weekend as long as the rain holds off because it started humming kind of loud yesterday.
Old May 17, 2011 | 06:09 PM
BVFD54's Avatar
update on the truck.... I believe it is the pinion bearings and pinion seal I need to replace..... as for the power my truck today was boosting 10 psi easily had all kinds of power (never went over 10psi)......
Old Aug 30, 2014 | 02:00 PM
ALWAYSREADYROB's Avatar
Mi 94 idi factory turbo with hypermax air induction, clean K & N air filter... New fuel filter , recently within 2 yrs rebuilt E4OD Auto trans and no other mods.... Is showing same symptoms .. Lack of power. It has a rebuilt IP.. No smoke at all and no blinking limp mode light . What was the fix to your power problem ? I have EGT guage andboost guage but the most boost i get from the ol 7.3 is 5-6 lbs !
Old Sep 4, 2014 | 07:08 PM
4x4manonbroke's Avatar
I have a 3.55 sterling rear diff for sale ... recent brakes and bearings .. 350.00 Pm if interested ..
May 10, 2015 10:57 PM
explorer197143
Dec 28, 2014 01:14 PM
