No speed
Old May 11, 2011 | 02:18 PM
rogerz's Avatar
Default No speed
2006 Chevy silverado 6.6 hd duramax will not obtain highway speeds Maximum speed is 25 miles per hour Changed fuel and air filters, crankshaft and camshaft sensors and the fuel pressure regulator with no improvement What is the problem? Any suggestions please
Old May 11, 2011 | 08:25 PM
cummin_un_glued's Avatar
FormerVendor
have you tried the rail pressure relif valve? you really need to hook it up to a good scanner and check the rail pressure that will tell you alot. also will it rev up more then 2000 rpm?
cjt8569
Sep 29, 2015 06:39 PM
Dertyd
24
Jun 7, 2015 02:45 PM
Taylor03
Jun 6, 2015 11:09 AM
May 17, 2015 12:10 PM
F250MACH
Apr 26, 2015 05:19 PM
