Radiator/Trans cooler
After doing alot of reading on trans coolers and the need to replace my radiator I decided to do both at once. I'm using a radiator from Rockauto: Vista-Pro 431330 (OEM numbers 1725, 9413, 99413) - fits w/o AC, w/ HD cooling, w/ AC, w/ MAX cooling More Information for VISTA-PRO 431330 and a TruCool 4739-1 w/o bypass: Tru-Cool MAX transmission cooler *without external cold weather thermal bypass Makco Transmission Parts and am routing in sequence.
Just wondering will the stuff I've chosin work together (3 diffrent radiators is the problem) or do I need to order something else? Am I going to need anything special to do this? Any extra parts or fittings I may need? Any idea how much trans fluid I will need to fill the new cooler?
Yeah t-stat is about 2 months old, water neck is a month and I'm going to do a new o-ring when I pull things off. Being "easy" never works for me, something always causes issues-spent 2 hours re-wiring my fog lights only to have to pull then out to put in new bulbs
Bighouse
Apr 9, 2015 06:51 PM
mcompton1973
Feb 11, 2015 12:00 PM
FlyingDutcman
Oct 28, 2014 04:56 PM
