chip or programmer help please
Old May 9, 2011 | 08:53 AM
bigEd's Avatar
Default chip or programmer help please
hey everyone I need a little help here i want to get some better preformance out of my truck with out killed me in the wallet area. I want to chip it. or run a tuner or programer. I dont really want anything that will destory my engine or trans. I have a 1997 f250 7.3 with the E40D trans tha was rebuile 20k ago with a billet torque convertor. What would be my best bet can you guys help me out thank you.
Old May 9, 2011 | 09:08 AM
TS 6pos Chip
Old May 9, 2011 | 09:19 AM
95powersmoker's Avatar
What he said ^^^ TS chip with custom tunes, it will be much nicer on your tranny and wake that truck up a bit...
First off, you want to do an intake, exhaust with aftermarket 3" downpipe and gauges... Then chip it.
Old May 9, 2011 | 09:48 AM
95-SimpsonOBS's Avatar
TS 6 Pos chip with custom tunes. after exhaust intake and with gauges like powersmoker said
Old May 9, 2011 | 08:34 PM
bigEd's Avatar
well i got an intake on my truck already its cold air. 3 inch down pipe is on my list of to do thing forst i got to get wheel bearings tires and an upgraded transcooler. What would the gauages be used for. I assuming trans temp ehaust temp and boost?
Old May 9, 2011 | 08:38 PM
Yep, At the very least you want an EGT gauge to keep an eye on temps especially after chipping a truck. Trans temp will help you keep an eye on your transmission. Boost is really just for fun but can also tell you if you have any boost leaks or not.
Old May 9, 2011 | 08:48 PM
bigEd's Avatar
you guys with the 6 position tuners i just googled tw 6 pos and it showed me like what options you can get is the ts 6 position do the same?
Old May 9, 2011 | 08:52 PM
TS chip is the base product that most every custom tuner sells...
Every tuner is different in the way they tune but the tunes basically all accomplish the same thing.
Because you have stock injectors with about 90cc worth of fuel. If you get a 140 hp tune, you will only get about 60 of those...
Old May 9, 2011 | 09:28 PM
bigEd's Avatar
the website i looked at is called ktpreformance.com i was thinking of doing
1.stock
2.smoke
3. 65hp moderate tow
4.high idle 1.200 rpms
5.80hp preformance
6.100 hp race
do you think this is a good set up. What would you guys recommend?
Old May 9, 2011 | 09:34 PM
Looks good, I personally think the smoke tune is a waste though... You won't get smoke from stock injectors...
High idle is a great tune.
