Anyone running rear air bags?
Old May 8, 2011 | 09:58 PM
Gas's Avatar
Gas
Default Anyone running rear air bags?
Friends,
My Cummins usually has a load in the back but I still wouldn't mind a softer rear ride over city roads. Has anyone installed rear airbags and removed a leaf or two? I have a 2wd and it rides real nice in the front. I think if I pulled a leaf or two from the rear pack but added air bags I would have a nice soft ride and I could pump up the air bags when I load it down. Any thoughts on how much better the ride can get and how it will handle weight? I have a stock motor and I don't want to modify it so with stock power will I get axle wrap if I remove a leaf or two and add the air bags?
Old May 9, 2011 | 02:44 PM
91 rattler's Avatar
Default air bags
i have a 91 with airbags and i love them.
Old May 9, 2011 | 03:40 PM
Gas's Avatar
Gas
Any details?
Old May 9, 2011 | 07:06 PM
huntinguy's Avatar
You will get axle wrap if you take leaves out.
Old May 9, 2011 | 08:05 PM
901stgen's Avatar
I'm running airbags but it makes the ride worse.
Old May 9, 2011 | 11:28 PM
crazy clem's Avatar
im running the kelderman airride where the rear shackles and spring hangers are replaced by a airbag. nice and cushy .
Old May 10, 2011 | 07:47 AM
Gas's Avatar
Gas
I wish I could afford that!
So even if I remove a single thicker leaf I am going to get axle wrap? I hate axle wrap.
Old May 10, 2011 | 03:02 PM
Edahall's Avatar
Originally Posted by Gas
Friends,
My dad did the exact thing you mentioned on his chevy pickup and while it made it ride a lot softer, he experienced axle wrap. However, the axle wrap subsided considerably once he corrected the axle vs. driveline angles. Also worth mentioning is he just left 3 leaves per side. My recommendation would be to just try it out and let us know how it works. If you do get axle wrap, you might have to correct your axle to driveline angles with some wedges. Also, there are ways to get rid of axle wrap such as installing traction / ladder bars.
Old Jul 17, 2011 | 12:30 AM
91 rattler's Avatar
i use the airbags on my 91 dodge cummins to help it hold the loads i haul i leave about 5 pounds when i'm unloaded and it rides like it did when i had just leaf springs.
Old Jul 18, 2011 | 12:04 AM
1STGENFARMBOY's Avatar
My truck has 7 springs on all 4 corners, it rides like a hay wagon.
I just put Riderights on it last week to handle my camper but i shure
would like to take out a spring or two to make it ride a little better
unloaded.
Darwin
