6.5 diesel chevy p/u dies, stalls suddenly!
Old May 6, 2011 | 01:23 PM
wrangler's Avatar
Default 6.5 diesel chevy p/u dies, stalls suddenly!
i'm new here just found site my chevy p/u dies, stalls suddenly its a 6.5 turbo diesel
any thoughts on why?
Old May 6, 2011 | 11:08 PM
Crazy's Avatar
well are you getting any codes and when stalls does it start right back up could be bad PMD ,LP or OPS that cause that or sucking air if fuel line need more info to help you out
Old May 7, 2011 | 02:43 PM
wrangler's Avatar
fuel pump on frame works but no fuel to injectors.
no codes.
Old May 7, 2011 | 03:05 PM
Redram01's Avatar
My 95 did the same thing. I took the pmd off and put some dielectric grease on it. hope that helps.
Old May 8, 2011 | 10:34 AM
Crazy's Avatar
what yr is your 6.5
I would also check fuel shut off Solenoid make sure it working
Check all your grounds they play big part with these trucks there is 2 or 3 grounds at right back on intakes bolt and the there is grounds straps right under a/c dryer one goes to back of head and other goes to the frame then there one for PMD on top IP and one off the right battery to the fender
Here reading this maybe some help to you
www.AccurateDiesel.com - PMD Installation Instructions - Accurate Technical Services, LLC
Old May 9, 2011 | 07:52 PM
wrangler's Avatar
dielectrical grease didn't help
solenoid clicks
grounds good
Old May 9, 2011 | 08:09 PM
acesneights1's Avatar
If your PMD is on the Pump, it's probably dead. As a 6.5 owner....carry a spare.
Old May 15, 2011 | 05:26 PM
wrangler's Avatar
what is the best pmd kit?
Old May 17, 2011 | 01:50 PM
jasonduke5's Avatar
this is where i got mine PMDCABLE.COM and i got a turbo boost bolt here also. It was a snap shipped fast and had not problem ever thing worked just like it should
Old May 17, 2011 | 11:21 PM
ssgstank's Avatar
Leroy Lenza who owns pmd cable .com is a real good guy and ships stuff same day. I was having some problems with a cable he sold me and he spent a good deal of time on the phone with me to get it sorted out. I bought a Stanadine pmd from him and relocation cable and my truck has run real good sense then.
