Edge Juice and Tow/Haul
Old Apr 28, 2011 | 09:29 AM
bassking16's Avatar
Question Edge Juice and Tow/Haul
I will be installing an Edge Juice with Attitude this weekend, and was wondering if it is still necessary and/or recommended to use the tow/haul setting on my truck when towing once the edge is installed. My truck is an 06 Mega Cab 5.9 Cummins, and I two a 21ft bass boat on a regular basis, and once a month or so, I will tow my 33ft travel trailer.
One other question... What does y'alls trucks idle at. My tach is jumping around a bit when the truck is cold, but says it's idling around 200 rpm. I'm not a diesle guru, but that seems a little low. Truck runs fine and seems normal though. I've read on here that a needle that jumps around is a sure sign that my tach is on its way out. I'm taking it in for some warranty work this afternoon, and I'd like to know if I need to bring this up to the tech.
Thanks Everyone.
Old Apr 28, 2011 | 10:00 AM
crusty_critter03's Avatar
200 rpm? i have an 03 and it has always idled around 800-900 rpm
Old Apr 28, 2011 | 10:47 AM
RAW's Avatar
RAW
I would still use teh Tow/Haul mode, as it doesn't change you engine power at all, to my knowledge. It changes your shift points, and down shifts to aide in slowing down.
Old Apr 28, 2011 | 10:48 AM
bassking16's Avatar
That's why I asked the question. I thought that was a little low for an idle. Like I said, the truck itself idles good, but the tach seems off.
Old Apr 29, 2011 | 11:02 AM
K80's Avatar
K80
Your in-dash tach is whacked out like a lot of us with an 06. I believe it was more of an 06 issue. Mine does it also. When you get your edge installed you should see it idleing at 800rpm.
