Big Rigs & Semis Discussion of Diesels Used for Transportation of Goods
DT466
Old Apr 26, 2011 | 10:05 PM
racecar's Avatar
Default DT466
I went to crank up the pump and set the timing as nevrenufhp has in his vids, thought I would install a pyro post turbo so I don't melt anything down. Did a test run before with 5 ton in the box up a big long hill, hit 950 on the pyro! I think that is the max temp? If I adjust timing to 19 degrees will that give more heat?
Old Apr 26, 2011 | 10:55 PM
nevrenufhp's Avatar
The timing brings down the EGT
Old Apr 26, 2011 | 11:04 PM
racecar's Avatar
Thanks for the help Nevrenufhp, your vids are great. How can I tell what mark on the dampener are 19 degrees? Are they all numbered or just marks? Is there a way on counting the marks?
Thanks
Old Apr 27, 2011 | 08:50 PM
nevrenufhp's Avatar
If you look close, you might be able to see a 10 and 20* marker. Otherwise, find TDC, and count the hash marks backwards. Roll the engine in reverse from the alternator(only spins it in reverse if the belt is adjusted properly). From TDC, either count the hash marks individually, or measure off desired amount(each degree = roughly 1/8"). You just dont live close enuf to me, otherwise, I'd just do it for you.
Old Apr 28, 2011 | 08:14 PM
racecar's Avatar
I will try to find the 10 or 20 mark and go from there. If my turbo was down on boost because of poor adjustment on waste gate and I adjusted it for more boost would that increase exhaust temps or lower?
Thanks
Old Apr 28, 2011 | 09:26 PM
nevrenufhp's Avatar
Adjusting for more booost will cause too much drive pressure in the higher rpm, and end up with real high EGT. Stock setting is best. Dump more fuel in it for more booost. Come to think of it, the older ones didnt normally get a wastegated turbo. Not til roughly 1993.
Old Apr 30, 2011 | 03:16 PM
racecar's Avatar
I right it is not wastegated...thinking of the 7.3 idi turbo on the bench.
Alan Scarlett
Big Rigs & Semis
Jul 23, 2015 11:19 PM
bigbadDT
Diesel Engine Conversions
Feb 26, 2015 06:48 PM
Stick_Welder
For Sale
Dec 28, 2014 10:16 PM
