99-03 7.3L Performance Discussion of 99-03 7.3 Liter Ford Powerstroke Turbo Diesels Related To Performance And Longevity
Turbo boost gauge
Old Apr 23, 2011 | 09:35 AM
Big bubba's Avatar
Default Turbo boost gauge
What is the right place to tap the x pipe for the boost gauge?
Old Apr 23, 2011 | 10:16 AM
CSIPSD's Avatar
You can tap it on the hot side, or the cold side, or tap the MAP line with a brass T
The hot side is right after the turbo compressor, which will read a bit higher then the cold side.
Cold side is after the intercooler... RiffRaff sells a nice plug that removes the Intake Air Heater and replaces it with a plug that you can install the boost gauge there...
Riffraff Diesel: RDP AIH Tapped Fitting
Or you can build a Brass T with barbed fittings on two sides and a 1/8" compression fitting on the other...
Old Apr 24, 2011 | 12:58 PM
ZombieSoldier's Avatar
CSIPSD, is there a preferred side to mount it? i know it can be done on either side, but which one would be more suited for accurate monitoring? I am assuming cold side as that is the side going to the motor?
Old Apr 24, 2011 | 01:07 PM
CSIPSD's Avatar
Cold side is where most mount it, so your numbers would be comparable.
Old Apr 25, 2011 | 02:58 AM
ok good to know. thanks bud
Devon7.3
Sep 22, 2015 07:59 AM
MrCat4974
Mar 23, 2015 11:30 PM
n2brk
Feb 21, 2015 09:05 AM
offroad00
24
Oct 23, 2014 03:28 PM
GreenDieselF
Oct 20, 2014 02:05 PM
