6.4 Oil Leaks
Ok here is the scoop! I bought my 08 in May of 09 ( used of course ) smoked from day ( oh this is gonna take a minute please bear with me), one, I took it back ( extended warranty ) they said " it's a Diesel it's supposed to smoke " so I went on my way. A few other issue's EGR valve failure, loss of power ( fixed ), rear seal on drive shaft leak ( fixed ), tranny leak ( fixed ), now starting in November last year there started a leak under the engine ??
, took it in they ( the dealership ) indicated " well we think it's the rear main seal, but we dont have time to fix it at this time our diesel mechanics are on vacation!" however it's a small enough leak you can bring it back" ( sorry this is getting to be long winded ) So I kept an eye on the oil level, dealt with the oil leaks on my new driveway, and took in, well after the first time, still leaking, second leaked worse then the first time ( actually pulled up to the service department and waited for about 5 minutes before I walked in, so my truck acted like a new born pup pissin on the floor leaving a nice big puddle ) I informed the service manager if you let the last tech who worked on truck, near my truck to fix this, not only will Ford hear from me the owner of your dealership will aswell. senior tech gets it, says fixes this problem ( oh forgot to mention each time they have my truck it's there for a full week ) get it home still leaking, take it back, I go into the shop so I can see what they are looing at, I point it out, " oh that is residual oil from the first time it leaked.....
at which point I think to myself ( WHOHOO here is my opportunity to get a new DPF
) tech says well its gonna take a week
at which point I say what else is new. well I have to do some diagnostics and get with Ford online
... Well today is officially the 5th week they have worked on my truck and guess what NEW DPF no more smoke, ( drink a little drink smoke a little smoke
) still the same no "REAL" power issue, but did notice improvement in fuel milage, they said ( about the leak ) we put your truck in the air on the lift and even had it " TILTED " down to drain the remnant oil. Well got it home looked underneath and guess what OIL LEAK!!!!!
I was told that in the bell housing there are cavities that will store leaked oil and it is very very hard to get that oil out and when it is driven will cause it look like it has a leak, Just wondering if ANYONE has had this issue.......
Funny thing the service writer just told me that today, I asked him should it be drained till it is empty ( last time I checked it, it smelled like diesel so i figured it was good ) what am i looking for here?
Do you know?
Ok just a little side note I was under the beasts belly this am and removed the rubber grommet on the front of the bell housing, stuck in my finger and quess what NO OIL!!!!, I'm begining to think that the Dealership MECHS are well
update:::: New DPF, had to take my truck back to the dealer because the last time they had it they put the cab back on crooked ( more to one side then straight ) and I mentioned the diesel smell, well they had for 4 days and said that they pulled the cab ( back on straight now ) and when they pulled the trany they found alot of oil in the bell housing
I have had it back for 2 days now but only driven it once ( on-call with the yob and all
so I am looking forward to seeing if EVERYTHING is finally taken care of will update next week. Happy Memorial Day. Have a Safe Weekend.
vin_diesel
Sep 15, 2015 11:25 AM
coors_man_2005
Dec 15, 2014 10:23 AM
