Tranny
Old Apr 18, 2011 | 11:22 AM
MechanicalDiesel's Avatar
Default Tranny
I just put in my new tc and it seemed fine at first but not even a minute into driving it, the truck wont move until I floor it and it barely even moves, feels like I got no fluid but the dipstick says its full. I dont know what to do. HELP
Old Apr 18, 2011 | 05:14 PM
cummin_un_glued's Avatar
FormerVendor
possibly you didnt get the tc keyed into the front pump?
Old Apr 18, 2011 | 06:12 PM
daveO's Avatar
Maybe your tc doesn't have any fluid in it. Did you try running the truck with the trans in neutral for a few mins?
Old Apr 18, 2011 | 08:37 PM
Yeah I had it in neutral and filled it up, even left it in neutral for a little while just to be sure, I dont know maybe ill have to pull the tc and send it back for another, but who knows if it will happen again or not. this is killing me its my daily driver too.
Old Apr 20, 2011 | 08:46 AM
Cummin un glued you were right, I replaced the flexplate with a used one and it was bent causing my tc to hit my front pump, so im getting my whole tranny rebuilt and everything replaced than my valve body modified and a few electrical stuff replaced. thanks guys for the help
Old Apr 21, 2011 | 01:52 PM
12workinprogress's Avatar
my truck did something like this when i replaced my tc and valve body. Called the dealer after i installed them and i was told to replace the governor sensor, lock up and od solenoids. i called around and sure enough 9 out of 10 said to replace these first then go from ther if there still is a problem. They all had said its pretty common for these to go bad. Put them in and everything is fine now. Part #K22954B PATC 46RE 47RE 48RE Transmissions, Performance Transmission A518, 518 Converter
InheritedDiesel
Jun 3, 2015 09:39 PM
peterbilt
Chevy/GMC Duramax 06-07 LBZ
Apr 8, 2015 10:33 AM
wilki
Feb 12, 2015 09:04 AM
Ol' RED!
Dec 11, 2014 10:00 AM
Trevlar11
Nov 16, 2014 01:59 PM
