Diesel Dawgs Performance Visit - Diesel Dawgs Performance
Smarty SSR
Old Apr 14, 2011 | 01:51 PM
FormerVendor
Default Smarty SSR
Diesel Dawgs Performance now has the long awaited Smarty SSR ready to ship!!!!
How it works
The SSR provides just one base performance software that
takes care of all the limiting factors like the speed / RPM /
Torque & boost limiters. Then you will need to fine tune the
injection duration, injection timing & rail pressure to the truck's
needs. The three most critical performance parameters in a
Diesel engine!
In order to allow the complete customization of the performance
software to the particular engine's needs, the SSR provides 50
levels each for the following parameters:
1) Low Load injection Timing ( LLT )
2) High Load injection Timing ( HLT )
3) Low Load injection Duration ( LLD )
4) High Load injection duration ( HLD )
5) Low Load Rail Pressure ( LLRP )
6) High Load Rail Pressure ( HLRP )
All you need to do is to select the tuning parameters that match
your truck best.
Power on Demand
100 power levels selectable in just one second during the
driving!
It's easy: just type the preferred power level directly on Smarty
keyboard, from 00 to 99. That's all!
For security reason, the truck waits that the throttle is released
before applying the new power level.
No trace is left in the ECM!
I herby CLAIM that Smarty is the FIRST AND ONLY downloader
that does not erase any of the stored data in the ECM. Smarty
does NOT leave any electronic footprints in the ECM or any
other electronic module in the truck. Smarty does NOT set ANY
codes once the ECM is set back to stock. Smarty does NOT
need to have fuses pulled.
No matter what the competition claims , in one way or another
they're ALL detectable.
Smarty is NOT!
Yet, Smarty can not do one thing for you. Fix what others have
broken. Smarty can not restore a key on counter that another
downloader has erased . Smarty can not fix VIN# troubles
caused by other products. If your Check engine / ABS light is on
because another product has screwed your ECM, Smarty can
not fix it, the other guy HAS to...
$735 Shipped UPS Next Day Air
Smarty SSR
Old Apr 16, 2011 | 04:25 PM
FormerVendor
Sold 5 the first day
Old Apr 18, 2011 | 05:49 PM
Redpatcher0481's Avatar
Got it today! Thanks Luke!
Old Apr 18, 2011 | 06:11 PM
FormerVendor
Thanks again for your Business
Old May 7, 2011 | 12:25 PM
FormerVendor
Jmrobinson
Sep 13, 2015 09:46 PM
Jmrobinson
Sep 13, 2015 09:44 PM
Apr 20, 2015 07:40 PM
Oct 28, 2014 07:00 PM
