95 dodge 2500 bushing replacement
Old Apr 12, 2011 | 11:17 PM
Mike H's Avatar
Default 95 dodge 2500 bushing replacement
Ive just ordered new bushings for my rear leaf spring and shackle.I have never replaced any bushings on my truck before, and would like to know what the best way to do them is.Also, do i have to have them press fit?any imput is greatly appreciated.thanks
Old Apr 13, 2011 | 12:37 PM
1AMatt's Avatar
Site Sponsor - 1aauto
Taking them out is AWFUL... Usually they dont come out without lots of torching, pressing, and hammering I believe aftermarket bushings are usually a two piece correct? They are normally cake to install
Old Apr 19, 2011 | 12:07 AM
Mike H's Avatar
thanks for the reply matt.I have not recieved my bushings yet,so I havent done the job.A friend of mine says that I will have to press the new ones in place.The bushings I ordered are polyurethane from energy suspension and im not certain that they are two piece.Do they have to be pressed in a a one piece?
Old Apr 19, 2011 | 07:27 AM
Red_Rattler's Avatar
High Tech Redneck
Will be def 2 piece if they are poly. You can press in one side at a time then insert the sleeve afterwards. But yes they will be a fight to get the old ones out
Old Apr 19, 2011 | 03:44 PM
1AMatt's Avatar
Two piece bushings are easy. getting old bushings out is not
Old Apr 20, 2011 | 08:19 PM
Mike H's Avatar
Good news, my bushings came today and they are 2 pieceNow I am getting ready to start,do you guys recommend removing the leaf spring itself?that would be a ton of work and I hate to do it if i dont have to,but if it is not possible without then i'll do it.
Old Apr 20, 2011 | 08:36 PM
High Tech Redneck
no need to take them all the way off, just hope you have a torch handy...
Old Apr 21, 2011 | 09:37 AM
1AMatt's Avatar
Yep... You will most likely need to torch the hell outa them
Old Apr 25, 2011 | 07:05 PM
Mike H's Avatar
sorry for the time lapse in between my posts.do I need to drop the axle?How long does it usually take to replace the bushings?I dont have a good place to jack up the truck at my house,but at my school I have an hour long auto period.so its possible,but difficult to get things done.Will it work to do one side at a time?Then I could knock it out in two days.
Old May 3, 2011 | 09:56 AM
1AMatt's Avatar
Depending on how stubborn the bushings are they may take a lot longer than an hour to get out...
