A New Truck for me?
Old Apr 12, 2011 | 05:40 PM
Rakkasan12's Avatar
Default A New Truck for me?
I'm starting a small auto hauling business. I've got a 5 car trailer and a 2 car trailer. I've done my research on these trucks and I've narrowed it down between an '11 3500 Silverado Duramax and an '11 F-350. I was however pondering a F-450. Would the 450 give me any edge over the duramax or 350?
Thanks guys.
Old Apr 12, 2011 | 05:47 PM
prison's Avatar
the 450 has some steering thing. maybe someone else can elaborate on that. 350 doesn't and 3500 probably doesnt. 450 has lower gears which will help depending on the weight your pulling. both great trucks.
Old Apr 14, 2011 | 02:41 AM
EasternAggie's Avatar
From all the tests and articles Ive read the LML Dmax seems to be a better engine than the 6.7 PowerStroke, but honestly either truck will do whatever you need it to with ease.
I would also think the 450 would have bigger brakes (better stopping power) along with the lower gearing, probably stronger axles and frame also.
Old Apr 14, 2011 | 08:02 AM
rhurley's Avatar
There was a huge write up in diesel power.. i think. THey tested em here in co, both had a trailer with a lot of weight on it. and the Chevy blew the ford out of the water. It was not even close. here read this!!
http://blogs.dieselpowermag.com/6729...oke/index.html
Old Apr 14, 2011 | 01:27 PM
Thanks for the link that was the write up I was thinkin of.
Old Apr 15, 2011 | 12:07 PM
Rakkasan12's Avatar
Default Chevy
I'm more of a chevy guy anyways and thats what I was leaning toward getting. That article really helped. Now I'm not sure if I should just go with the Kodiak C4500. I know GM quit making them so I'd have to get used but that isn't a problem. Any thoughts on those?
Old Apr 15, 2011 | 05:16 PM
You could, but a new 3500 with the LML will have the most power. If you was going to get an older C4500, I would just get a new 6.7L F450 or F550.
Old Apr 15, 2011 | 05:18 PM
rhurley's Avatar
Having test drivin both a '11 chevy and '11 ford. I would say chevy. It over all feels like it has way more to it.
Old Apr 15, 2011 | 05:34 PM
Rakkasan12's Avatar
I think I'm gonna go with the duramax. I was also thinking about putting a bully dog system in once I got it just to manage power out put and fuel economy better. Any thoughts on this system or any others?
Old Apr 15, 2011 | 08:39 PM
Either that or H&S, they both have tuning out for the LML's. The best route would be to run a turbo back exhaust and do a DPF delete with the H&S MiniMaxx or BlackMaxx, but you would lose your factory warranty. Engine will breath much easier allowing for more power and better mileage, but again, you lose your warranty.
Just make sure if you get a tuner that you can remove it without it leaving a foot print in case you have to take it to the dealer for work.
