how much boost????
Old Apr 10, 2011 | 10:07 PM
94Cumminz's Avatar
Default how much boost????
how much boost should i be getting out of a stock turbo with a mild pump tune?
Old Apr 11, 2011 | 03:36 AM
dieseldawg's Avatar
200 psi
haha couldnt resist!
between 20 and 30 ish mabey more?
why are you concerned with boost??
Last edited by dieseldawg; Apr 11, 2011 at 03:36 AM. Reason: Automerged Doublepost
Old Apr 11, 2011 | 02:41 PM
94Cumminz's Avatar
i just put a boost gauge in and cant even hit 10
Old Apr 11, 2011 | 03:40 PM
olsmokie47's Avatar
i get about 7-8 with fuel pin turnd and fuel pin washer taken off
Old Apr 11, 2011 | 06:56 PM
tower_ofpower's Avatar
wow... i must be rapeing my turbo then, i see atleast 25 psi. its just a rough estimate because the needle wraps around past the scale.
Old Apr 12, 2011 | 06:44 AM
cumminskid92's Avatar
i can push 45 with mine but is a hybrid.
Old Apr 12, 2011 | 11:19 AM
Levi Miller's Avatar
guys what kind of gauges are you using and where are you installin your gauges??? with my old stocker and a 60mm upgrade and a wastegated exhaust housing i could turn 30 7 to 10 psi isnt good i run 9 psi going down the highway thats not in the throttle just on cruise control check your lines, did you put teflon tape on the connections ill check around because i know 7 psi isnt good
Old Apr 12, 2011 | 02:38 PM
94Cumminz's Avatar
i could have a boost leak i will have to check and see
Old Apr 12, 2011 | 03:01 PM
i would say so. hopefully its that easy atleast.
Old Apr 12, 2011 | 04:11 PM
RSWORDS's Avatar
Alot of guys in here sound like they have a boost leak.
