HPOP oil
So I understand it runs off engine oil but does it pull it from the pan or is it seperate and if seperate is there a certain type/weight of oil I should use to fill it up if it's low?
no its not separate, the low pressure pump feeds oil from the pan up to the HPOP, and it shouldnt be low unless a pump is weak i believe, (but i maybe wrong) you might wait ta hear ta see what someone else has ta say also LOL
Durtyd09
Nov 11, 2015 01:43 PM
vin_diesel
Sep 15, 2015 11:25 AM
coors_man_2005
Dec 15, 2014 10:23 AM
, you're on the right track, change the oil, start the truck and you just changed the HPOP oil.
