turning up pump
Old Apr 9, 2011 | 04:34 PM
ruffneck6969's Avatar
Default turning up pump
hello all i have a question here i plan on getting a 88 f250 with 150000 miles an i want to turn up the pump i read the sticky an its easy to understand i plan on turning it up a 1/4 to half a turn i dont have a meter so will this harm the motor
Old Apr 9, 2011 | 06:35 PM
BVFD54's Avatar
I would not recommed that you turn the fuel up at all unless you get a pyrometer.... You may end up with a nice ornament in your driveway. If you are serious about turning up your fuel and want to take care of your engine you need to spend the money to get the pyrometer to monitor the EGTs.
Old Apr 9, 2011 | 06:54 PM
ok so i just need to get a egt guadge then so wheres it hook to on the exhaust
Old Apr 9, 2011 | 10:14 PM
DieselCrawler's Avatar
drill and tap a hole in the driverside manifold near the rear. if it isnt a turboed motor, just drill and tap it. dont worry about the shavings. normal pyros use a 1/8 pipe thread.
Back-in-Black
Chevy/GMC Duramax 01-04 LB7
8
Aug 13, 2017 10:35 PM
landon025
Sep 8, 2015 09:21 PM
HardLuck
Jun 24, 2015 08:04 AM
Renteria1217
Apr 16, 2015 11:38 PM
jmerriman17
Nov 10, 2014 02:44 PM
