6.0L Performance Discussion of 6.0 Liter Ford Powerstroke Turbo Diesels Related To Performance And Longevity
headstuds?
Old Apr 3, 2011 | 02:35 AM
strokedout07's Avatar
Default headstuds?
I have been told by a few individuals you can put headstuds in your truck by simply pulling the bolts out one at a time and replace them with a stud as you go I find this hard to belive can anyone give me some insight on this please
Old Apr 3, 2011 | 03:13 AM
WIRedneck's Avatar
I can't say for sure either way, but I would not trust that method...
Old Apr 3, 2011 | 03:22 AM
prison's Avatar
it would probably still stay seated. for best results of course you're gonna want to install new gaskets but if your on a tight budget you could probably get away with your method
Old Apr 3, 2011 | 06:18 PM
stone's Avatar
I dont no if thats true, but i do no its pointless to do headstuds unless u have ur heads decked to make sure their flat. Without that done ur still gonna blow headgaskets.
Old Apr 3, 2011 | 06:29 PM
prison's Avatar
if they stay seated you don't need to because its seated already. once you take them off you should so the surfaces seat properly
Old Apr 4, 2011 | 07:58 AM
Mdub707's Avatar
I've heard of a couple people doing this and even one member from another site who did this AFTER he started puking and it stopped.
Me personally, there is no way I'd even waste my time putting headstuds in without taking the heads off and having them decked.... coming from a guy who has blown 3 sets of headgaskets, once with ARP's installed by the dealer.
Old Apr 15, 2011 | 07:00 PM
Diesel_Daddy6.0's Avatar
How about in my case where I know the heads and gaskets are still good, no signs whatsoever of a failure. I just want to start making a little more power and add reliability. What are the torque specs for ingoing studs?
Old Apr 15, 2011 | 07:05 PM
95powersmoker's Avatar
Some 7.3 guys do that, one stud at a time...
If I had a 6.0 I think I'd be replacing the gasket though.
Old Apr 15, 2011 | 07:39 PM
newman's Avatar
I'm with Mike! Do it right the first time.
Probly can't slip a new gasket under there with cab still in place huh?
