P Pump Conversion
Old Apr 1, 2011 | 10:53 AM
connermcpherson's Avatar
Default P Pump Conversion
Just letting you guys know, ive done a few of these conversion and it seems like alot of people have questions and concerns on the swap. I run a 175 p pump on my 02 CTD and run it everyday as a DD. If you got any questions, ideas, concerns etc. please send me a PM and ill help ya out. Ive helped a few guys on here with their swaps and dont mind helping towards the cause you can shoot me a PM or send me a text at 941-256-1034. Good luck fellas
Old Aug 7, 2011 | 11:37 AM
wiseguy63's Avatar
im doin a conversion on my 24v and i was wondering how much timing and how much i should move the fuel plate and afc?
Old Aug 14, 2011 | 07:12 PM
wiseguy63's Avatar
also i ordered the conversion kit. it comes with ■Pump gear
■Gear housing
■Mounting studs and nuts
■Crank seal
■Housing gasket
■Vacuum pump kit
■24-P Tunnel Ram
■Intake gasket set
■Conversion injection lines w/brackets
■Pump mounting bracket
■Oil feed line & restrictor
■Overflow valve
■24V Apps throttle linkage kit
■Cam sensor adapter
Do i need anything else other than the pump and do i need to weld the cam gear after i change it?
Back-in-Black
Chevy/GMC Duramax 01-04 LB7
8
Aug 13, 2017 10:35 PM
landon025
Sep 8, 2015 09:21 PM
HardLuck
Jun 24, 2015 08:04 AM
Andrew1995
Wanted To Buy (WTB) - Used
Feb 25, 2015 03:44 PM
bonestock
Feb 1, 2015 08:41 PM
