03 "Popped" when getting on hiway
Old Mar 31, 2011 | 05:17 PM
turbohacker's Avatar
Default 03 "Popped" when getting on hiway
Hey all. Ive got an 03, 2wd with edge juice, airdog 100, afe and exaust. Ive needed injectors for a while but been saving for a schied set. I was getting on the hiway and layed into it. It pulled pretty good then I got a loud "Pop" sound and motor died. I checked for boost tubes and injector lines and leakage on the side of the road, then I tried to fire it up again and turned it over for a few mins. It would not fire. I had 17psi fuel pressure to the cp3 the entire time. I towed it home and it fired right up. What gives? Any ideas? Should i drive it? I checked two codes, 2146, and 2149, both are injector bank electrical signals. The truck seems to run normal now exept for the rough idle because of the sticky injectors, but it was like that before. Thanks. -Nick
Well i decided to just drive it. Its running about like it has this past couple months. Im really curious as to what it was though?? Im putting some 100 horse schied sticks and a vgt on this month so it will be all apart so I was wondering if there is anything I should look into? Thanks for the great site BTW, I hope someone will chime in!
Last edited by turbohacker; Mar 31, 2011 at 05:17 PM. Reason: Automerged Doublepost
Old Mar 31, 2011 | 09:50 PM
daveO's Avatar
Hmmm. Seems odd. I'm not sure what to tell you, but decided to give you a bump. Hopefully you'll get some ideas.
Old Apr 1, 2011 | 04:01 PM
pipeliner1000's Avatar
if it ever doesnt crank, unplug the fca connector, if ur injectors are leaking it wont make enough rail pressure to fire, unplugging the fca puts max rail pressure to it and makes it crank, then just plug it back in...my .02
