CFM rating
I've seen it before, but I cant recall.
NONE of the electric fans avalable will pull enough air to cool properly when towing. Empty you will be fine, but towing heavy you will run into issues.
I have had two friends buy the aftermarket electric fan set ups... Both are sitting in there garages or in the land fill.
If your looking for more HP, look elsewhere.
If its a race truck, remove the fan all together.
i just dont like the fan. and i think mine might be bent
i just read our fans pull 5900 cfm. jegs sells one for the superduty's that's 6200 cfm. i dont see one for the 94-97's so i may just test it out and adapt it. why not give it a shot. if its rated higher than our fan it shouldnt be a problem. then i can say that i have tried one made for it and if it worked or not. i'll write a review if i do it. are there any down sides to electrics though if they can pull a higher cfm?
Apr 16, 2015 10:10 AM
