Where is the best place to hook up gauges
Old Mar 25, 2011 | 12:57 PM
smokinstroke's Avatar
Default Where is the best place to hook up gauges
Where is the best place to put the pyro thermocouple(preturbo) and the fuel pressure?
Old Mar 25, 2011 | 03:40 PM
OceanDiesel's Avatar
Pyro, in the exhaust manifold.
Old Mar 25, 2011 | 05:28 PM
99stackedpowerstroke's Avatar
boost would be to pull the spyder pipe off the heads and drill and tap and put your boost there, or you can cut the hose coming from that to the map sensor which is on the passenger side and put a T there and put the boost hose there, but fuel i have no clue, and hes right for the pyro
Old Mar 25, 2011 | 05:32 PM
prison's Avatar
dont we have a fuel pressure test port on the side of the fuel bowl?
Old Mar 25, 2011 | 05:46 PM
I have a manual liquid filled gauge in the port with the schrader valve, but I didn't know if there was another spot I should be monitoring also. Is there any particular cylinder I should use, on my dodge, they said number five got the hottest. Thanks
Old Mar 25, 2011 | 06:41 PM
joebob3093's Avatar
Moderator
either side in the back of the manifold will work fine. you can hook a fuel pressure sender where the schreader valve is. the boost you can T off of the MAP sensor and the tranny has a port of the side of it.
flainn
Oct 12, 2024 09:39 AM
moparisthebest
Price Quote - Request A Price
Oct 21, 2015 07:31 PM
Powerstroke36
Sep 6, 2015 02:41 PM
May 1, 2015 08:10 AM
carid
Diesel Bombers Sponsors
Dec 9, 2014 03:58 AM
