fried PCM on 01 7.3??
Old Mar 21, 2011 | 09:18 PM
Lange503's Avatar
Default fried PCM on 01 7.3??
went to put on a 6 pos. chip on a 2001 7.3, unhooked batterys and everything, went to start and all it will do is crank, with the chip on or off the truck, any ideas???
Old Mar 23, 2011 | 09:28 AM
ffemt44169's Avatar
What kind of chip did you use?
Old Mar 23, 2011 | 12:07 PM
Lange503's Avatar
it was a custom one from PHP but the pcm was fried, i just swapped him with the one out of my 2003 7.3 and he's back on the road
Old Mar 29, 2011 | 01:42 PM
cfarley0210's Avatar
is it on the road with the chip in it? i would take that chip back and make them buy you that pcm they must have done something wrong when they were making the chip.
Old Mar 29, 2011 | 07:35 PM
Lange503's Avatar
my chip is in it seems how its my pcm, but i told him to call them about it, but we also could've fried it by static electricity, unlikely but still possible
Old Apr 3, 2011 | 12:16 PM
95powersmoker's Avatar
Were the keys in the ignition or the ignition not completely in the OFF position?
Did you overclean your contacts or not clean them enough?
Old Apr 3, 2011 | 03:37 PM
Lange503's Avatar
key was in his pocket so yes, and even if the contacts got over cleaned it should still run without the chip shouldnt it??
Old Apr 3, 2011 | 03:46 PM
CSIPSD's Avatar
Even if you over clean the PCM it will still run without the chip. Static can kill them, but it is EXTREAMLY rare.
I have never even unhooked the batterys when installing chips, just key out of the switch.
Very weird!
Old Apr 3, 2011 | 03:52 PM
That is weird..
Can he send the PCM and the chip back to PHP and have them test both to see what the issue is?
Old Apr 4, 2011 | 03:32 PM
Lange503's Avatar
thats what i'm having him do, in the mean time i gave him my chip and PCM so he can still have his trucks seems how mine is down anyways, i'll let you guys know what the issues ends up being
