Dodge Diesel Tech Articles All Years of Cummins Tech Talk
Fluid Capacities and Types
Old Mar 18, 2011 | 05:24 PM
wildbill's Avatar
Default Fluid Capacities and Types
Fuel Tank: ULSD Only
2500/3500 SB = 34 Gal
All Long Boxes = 35 Gal
Engine Oil W/ Filter: 15W-40 or 5W-40 Full Syn or Dino
12 Quarts
Power Steering: ATF+4
Power steering fluid capacities are dependent on engine/chassis options as well as steering gear/cooler options.
Depending on type and size of internal cooler, length and inside diameter of cooler lines, or use of an auxiliary
cooler, these capacities may vary.
Coolant System:
29.5 Qts or 7 Gal, 1.5 Qts (Includes 1 Qt for reservoir)
The use of aluminum cylinder blocks, cylinder heads, and water pumps requires special corrosion protection.
MoparT Antifreeze/Coolant, 5 Year/100,000 Mile Formula (MS-9769), or the equivalent ethylene glycol base coolant
with organic corrosion inhibitors (called HOAT, for Hybrid Organic Additive Technology) is recommended. This coolant
offers the best engine cooling without corrosion when mixed with 50% Ethylene Glycol and 50% distilled water
to obtain a freeze point of -37°C (-35°F). If it loses color or becomes contaminated, drain, flush, and replace with
fresh properly mixed coolant solution.
Automatic Transmission: ATF+4
42RLE Serv = 4 Qts
42RLE Overhaul = 17.6 pts
45RFE/545RFE Serv = 11 pts 4x2 or 13 pts 4x4
45RFE/545RFE Overhaul = 29-33 pts (depends on options)
48RE Serv = 4 Qts
48RE Overhaul = 29-33 pts (depends on options)
Manual Transmission: ATF+4
G56 = 12 pts (diesel engine)
Transfer Case: ATF+4
NV241, NV246, NV244 = 3.4 Pts
NV271, NV273 = 4 pts
Front Axle: 75W-90 Full Syn
C205FD 1.6 L (56 oz.)
9 1/4 AA 2.2 L (74 oz.)
9 1/4 AA EL 2.0 L (6.8 oz.)
Rear Axle
9 1/4 - Synthetic Gear Lubricant 75W-140
10 1/2 AA - Synthetic Gear Lubricant 75W-90
10 1/2 AA EL- Synthetic Gear Lubricant 75W-90
11 1/2 AA - Synthetic Gear Lubricant 75W-90
248RBI - Gear & Axle Lubricant SAE 90
NOTE: Trac-LokT differentials require Limited Slip Additive in the lubricant. Trac-Rite™ / Trac-Rite EL™ differentials
DO NOT require Limited Slip Additive.
