94 stalls after sitting for 30 min.
Old Mar 18, 2011 | 05:02 AM
pipelayer4777's Avatar
Default 94 stalls after sitting for 30 min.
If I start the truck in the morning it will run all day no problem, this after it sits all night. If I shut the truck off and get lunch, maybe half hour to up to 5 hours truck will start but will be missing and yesterday it finally stalled out and started right back up after I shut off and started again. any ideas, the lift pump, oil switch are all ok and 12volt is confirmed at pump at least it was a couple weeks ago. Any suggestions.
Old Mar 18, 2011 | 08:07 AM
Crazy's Avatar
how did you test the OPS and LP also where is the PMD mounted
Old Mar 20, 2011 | 05:46 AM
I am going to check the LP this afternoon again and the OPS is the OPtic sensor I assume. My PMD is mounted on the front bumper ans is brand new So in theaory it should not be the issue. Heath has a filter harness for the Optic sensor, I noticed the other day when getting the numbers off the IP for a prom that the harness filter was really hot. I'm also gonna pop in a new fuel filter today to be on the safe side. other than that the truck is running great, but every so often has a slight miss. I'll get it figured out.
Old Mar 20, 2011 | 12:37 PM
Crazy's Avatar
OPS ( Oil Pressure Switch)
redjello
Apr 13, 2015 08:27 PM
irishbmx
Nov 19, 2014 01:47 PM
