conversion planning stages questions
Old Mar 17, 2011 | 09:55 AM
52F3's Avatar
Default conversion planning stages questions
I have a 6bt out of a UPS truck that I'm in the planning stages of what to do to get it in my truck (1952 F3). The engine came with a power steering pump and vaccum pump. I'd like to run power steering and possible power brakes.
Power steering: How can I tell if the power steering pump on the motor will work with different steering boxes? My plan is to install a toyota power steering box from a late 80s to early 90s 4x4. I have a writeup on that install and it seems the best. Would it be better to buy the pump from the same truck and make mounting brakets?
Brakes: I'm not sure if I'm going to run power brakes yet. If I do will the vaccum pump work for a regular brake booster setup? I'm thinking about putting an exaust brake on the truck also. Are there any downsides to running an exhaust brake?
I haven't set the motor in the truck yet to check the fit but it looks like I may have a clearance issue with the solid front axle on the truck and the oil pan. Can I spin the oil pan 180 along with the pickup tube or will I need another pan/pick up tube?
Any help would be greatly appreciated. Thanks.
Old Mar 17, 2011 | 01:48 PM
beerbellykelly's Avatar
cummins do a bunch of options on oil pans and pick ups-
i,d rig the steering pump up with a mains motor,just connect the whole mess up ,spin it and see if it works,those steering pumps are all pretty powerful,i think the issue there is amounts of fluid and size/speed of ram
Mar 20, 2015 08:20 AM
Jan 13, 2015 09:00 PM
Nov 28, 2014 09:50 PM
sotomo
Nov 24, 2014 07:29 PM
Nov 12, 2014 08:10 AM
