Show And Tell Got Photos or Videos of Your Diesel ? - Post Here and Tell Us About it , We Support Most Video Sites , Diesel Videos will Auto Embed .
hid headache
Old Mar 16, 2011 | 07:57 PM
Rob_wells06's Avatar
Default hid headache
i ordered a hi/lo beam hid 6000k kit from hidgeeks.com. im having a issue and there customer service is non existent. called the 800 number for 2 days now and its constantly busy. anyways my problem is i hooked the kit up and had the flicker on and off and a lamp out light. in their instructions it says to get a hid resistor or a bulb out warning module, witch i figured i might as well order from them, they call it a error cancellor. hook it up and the same problem. anyone have any ideas or should i just cut my loses and toss the damn thing in the trash and by a decent hid kit.
Old Mar 16, 2011 | 09:17 PM
crzycummins's Avatar
was it a relay harness that you got?
Old Mar 16, 2011 | 10:31 PM
I got the balest's and the bulbs. Its got a power and some grounds. The error cancellors hook up to the ballast's. Its all hooked up right. Pretty simple plug ins. I don't know what the problem is.
Old Mar 17, 2011 | 07:23 AM
alot of places sell a relay harness, that is supposed to help the flickering i hear. also there is alot of vids on youtube about hid flicker and peoples fixes
Old Mar 17, 2011 | 10:17 AM
cummins army's Avatar
look up the hid factory in houston texas they sell a very nice harness that hooks to the batery through a relay and then you tap your head light wire it still uses the factory switch but bypasses all factory wiring thats what i had to do on mine cuz i had the same problem
Old Mar 18, 2011 | 08:16 AM
the kit came with a relay harness, still not working. ill put this put here so no one makes this same mistake. do not buy from hidgeeks.com.
Old Mar 18, 2011 | 09:34 AM
ZombieSoldier's Avatar
try 3B Specialties their kits are i run, and never ever have had an issue. little more expensive then most but well worth it.
Old Mar 23, 2011 | 07:35 PM
02LB7DURAMAX's Avatar
If you can't figure out whats wrong with them I would toss them and buy a better set. My brother and I bought ours from ddmtuning.com and the quality has been great, and they are BRIGHT, I bought my high/low beams and the whole kit including shipping was $86.00. I would highly recommened them. Hope this helps you out.
sujumptd
Audio Equipment/Electrical
Jan 16, 2016 07:40 PM
Adam Sanders
LB7 Performance
Jan 21, 2015 06:57 AM
