Turbo
Old Mar 16, 2011 | 07:05 PM
Logs0012's Avatar
Default Turbo
Will a 99 24 valve turbo work on a 95 12 valve exhaust manifold?
Old Mar 17, 2011 | 02:04 AM
12valvetater's Avatar
Yes.
Old Mar 17, 2011 | 08:17 AM
Logs0012's Avatar
Thank you sir!
Old Mar 19, 2011 | 10:11 AM
Logs0012's Avatar
Change of plans, will a 99 turbo fit On a 93 manifold?
Old Mar 19, 2011 | 12:32 PM
Ramman1994's Avatar
Yes
Well maybe 94 to 98 is the same in and out
Last edited by Ramman1994; Mar 19, 2011 at 12:32 PM. Reason: Automerged Doublepost
Old Mar 19, 2011 | 02:21 PM
cumminspwr11's Avatar
the turbo will if its just a t3 manifold until the 6.7 cummins, some 24vs came with a smaller 9cm exhaust housing, so just make sure you know what your getting
Old Mar 20, 2011 | 12:36 AM
Manual 24v engines had hx35's (12cm) Auto 24v engines had hy35's (9cm) All engines had a T3 foot until the 6.7. 24v turbos use a different oil inlet fitting but this is easily swapped.
avatardvr
18
Aug 8, 2019 12:38 AM
n2brk
Feb 21, 2015 09:05 AM
jrsavoie
Feb 6, 2015 09:44 PM
tumble72
8
Nov 27, 2014 10:31 PM
GreenDieselF
Oct 20, 2014 02:05 PM
