94-98 7.3L Performance Discussion of 94-98 7.3 Liter Ford Powerstroke Turbo Diesels Related To Performance And Longevity
biggest mods
Old Mar 15, 2011 | 12:30 PM
codyawise's Avatar
Default biggest mods
as for now my 97 stroker has a bully dog 6 pos chip, stage 2 injectors, custom intake, exhaust.
i have been satisfied with that for a good while but im at the point where i want to just make the thing nasty so what im askin what all can i do to make it truely nasty,
i want to bigger chip, bigger injectors, big turbo, airdog fuel, and anything else you guys can think of. also give me advice for bigger chip, injectors and turbo as well.
Thanks
Old Mar 15, 2011 | 12:55 PM
joebob3093's Avatar
Moderator
Default Re: biggest mods
Get the chip reburned and you will see a huge difference. If that's not enough you can go with large hybrids and a large single or compound turbos. Just all depends on the money you have to spend.
Old Mar 15, 2011 | 12:56 PM
95powersmoker's Avatar
Its only money...
Hybrids
H2E
HPOP
Tranmission/clutch
E-fuel
Springs, push rods, studs
gauges if you don't already
Custom tunes.
Old Mar 15, 2011 | 01:17 PM
codyawise's Avatar
i have thought bout some reburns but someone had said with the type of chip bully dog uses i may not be able to get it reburnt so i had been thinkin bout goin with a ts with custom tunes. and yes 95powersmoker is correct it is only money.
Old Mar 15, 2011 | 01:47 PM
You need to set a REALISTIC horsepower goal. Something you're going to want to drive ice, snow, sleet, wet, dry. Then go from there.
Old Mar 15, 2011 | 02:00 PM
codyawise's Avatar
realistic atleast 600 for now
Old Mar 15, 2011 | 05:02 PM
ccarrier's Avatar
first off, GET RID OF THAT CHIP!
Old Mar 15, 2011 | 05:10 PM
600 and you're going to want to call a few high horsepower builders and talk to them... 500 would be a better goal IMO if you're building it yourself. 600 and you need to start looking at girdles and other goodies...
Just my .02
Old Mar 16, 2011 | 12:19 PM
codyawise's Avatar
Yea im plannin on it.
And yea im more than likely goin to do it mostly myself. i mean i know plenty of guys that could give me a hand if i need it
Old Mar 16, 2011 | 04:20 PM
joebob3093's Avatar
Moderator
Pretty sure the bully dog 6pos is the same as a TS. cale at tyrant can reburn those
