excuse the ignorance
Old Mar 8, 2011 | 09:38 PM
97dieselnewb's Avatar
Default excuse the ignorance
Whats an upgraded valve body in your tranny do? does it just help with line pressure and lubrication? if so, how does it do it vaguely? what does it do?
Old Mar 8, 2011 | 10:43 PM
95powersmoker's Avatar
Pretty much, It directs fluid and regulates pressure..
Old Mar 8, 2011 | 10:46 PM
CSIPSD's Avatar
Changes shift firmness and timing, boost line pressures helping to keep the clutches locked up.
Old Mar 8, 2011 | 11:58 PM
So would an upgraded valve body be a good investment, Possibly tranny saving, on a truck with mild modifications?
Old Mar 9, 2011 | 01:58 AM
joebob3093's Avatar
Moderator
Default Re: excuse the ignorance
An upgreaded valve body would be a very good investment.
Old Mar 9, 2011 | 01:27 PM
whats a good valve body to go with? I was looking at the one at beans diesel
Old Mar 9, 2011 | 01:28 PM
BTS or RacerX gets my vote..
Old Mar 9, 2011 | 02:45 PM
joebob3093's Avatar
Moderator
I would go with bts or john woods
Sent from my DROIDX
Old Mar 12, 2011 | 05:59 PM
GT's's Avatar
I'd go for a BTS myself. A valve body isn't overy expensive but the problem is yes it can help prolong a transmissions life. However when the tranny goes it's going to be toast too from the debris getting into it. So if you have a very mild build then go for it and hope it all holds out. If you're going with a bit higher build then save your money for the full on transmission build later.
Old Mar 12, 2011 | 09:23 PM
85_305's Avatar
Being Evaluated
So are you saying toss a VB on it and call it a day? (Without putting in a better tc..)
