Adrenaline, kind of let down
Old Mar 7, 2011 | 02:39 PM
D-LUX's Avatar
Default Adrenaline, kind of let down
well the title says it all.. i replaced my injection pump and installed a new airdog 150 this weekend after my last pump seized up.... thing is with the other pump it ran alot stonger than it does now... now even with the comp tunes loaded and set on kill it barely smokes and i can only hit about 1100 degree's when before it was defueling at 1350... it is adding power but it really seems weak.. any idea's.. im almost to the point of wanting to switch to an edge comp/hot unlock...
Opinions welcome..
Old Mar 7, 2011 | 02:54 PM
chad83181's Avatar
Any codes or CEL's
Old Mar 7, 2011 | 02:56 PM
D-LUX's Avatar
nope nothing even ran my scanner on it and its normal... the pump i had before was a sfx from bluechip diesel but i dont think it was worth that much power.. what are yall opinions on the edge comp box?
Old Mar 7, 2011 | 03:57 PM
chad83181's Avatar
Have heard it's a BADA$$ Piece of electronics. Quite a few people run them on here.
Old Mar 7, 2011 | 05:13 PM
Rooster24v's Avatar
you deffinetly have something going on here.. id get ahold of quadzilla, mine on full kill will smoke out a whole intersection and then some... you should have some pretty impressive power with it all the way up.. id get ahold of them.
Old Mar 7, 2011 | 05:35 PM
D-LUX's Avatar
well from what i understand there's not a whole lot that can go wrong... i know its not running out of fuel w/ the airdog on it now but i will say the truck is a lot more sluggish with this new pump i installed
Old Mar 7, 2011 | 05:42 PM
RAW's Avatar
RAW
The COMP is unbeatable in smooth, hard fuelling, easy power, IMO. I have one, and when I really want to go I quickly install it. Other wise I run an EJWA CTS.
Old Mar 7, 2011 | 05:44 PM
D-LUX's Avatar
well i just got off there tech line and from what i explained to him it sounds like the pump tap wire isnt getting a good enough connection so hopefully this fixes it
Old Mar 7, 2011 | 06:17 PM
RAW's Avatar
RAW
Do you have a stealth plate? If not, I highly suggest one.
Old Mar 7, 2011 | 07:16 PM
D-LUX's Avatar
im actually gettin ready to buy one.. supposedly it doesnt void the pump warrenty correct?
