LB7 2003 smoke at idle
Old Mar 6, 2011 | 12:06 PM
Hoiman's Avatar
Default LB7 2003 smoke at idle
In the last couple of weeks I notice some blue smoke when I am idling. It only happens when idling and engine is warmed up. I have 80,000 miles on truck and this is the first time I am having trouble with it. I changed oil and filter and also fuel filter. I keep on looking at the oil level for possible fuel leak into sump. No change. However, it might be too early to tell because I only have 70 miles on it since the last oil change. I use the right specifications and viscosity for the oil. The air filter is an after market K&N filter. No trouble codes are displayed and it gives me a "no codes" on my OBD II scanner.
Please, give me your thoughts. Would it be advisable to drive home, about 2000 miles, or should I have it repaired asap. Also if only one injector leaks should I just replace this one and don't worry about the rest.
Thanks. Hoiman
Old Mar 7, 2011 | 12:17 AM
BriteWhiteRam's Avatar
Have your injector balance rates checked.....
Old Mar 7, 2011 | 08:21 AM
Hoiman's Avatar
Planning to have it scanned today to see what the injectors are doing. I am evaluating to see if I can drive it home to British Columbia where I have the tools and garage to work on it.
Thanks, BriteWhiteRam for your input.
Hoiman
Old Mar 7, 2011 | 11:58 AM
It shouldn't hurt it too badly, but just be nice to it, check the oil periodically to make sure you're not getting oil delusion, You can probably just replace the one or more that are bad, replacing all 8 would hurt
Old Mar 11, 2011 | 10:12 AM
cfarley0210's Avatar
i would repace all them if your going to replace any it would suck to get it all together and start it and end up with a fuel knock due to new and old injectors mixed
Old Mar 11, 2011 | 03:50 PM
2500HeavyDuty's Avatar
replace all of them, i just recently did an injector job and replaced only one (was out of specs) and the truck still smokes at idle
Old Mar 11, 2011 | 04:15 PM
DieselCrawler's Avatar
i didnt want to hear that. i got one injector way out on balance rates and haze at idle. wasnt looking forward to putting that much into it just to sell it.
Old Mar 11, 2011 | 04:19 PM
you can give it to me how it is, you dont have to sell it
Old Mar 11, 2011 | 05:37 PM
nah, was hoping to get back what i paid for it, but doubt it now. only paid 10000 for it.
Old Mar 12, 2011 | 06:18 AM
BRE's Avatar
BRE
I did one on a truck and like 3 months later we were back at it again... Twice the labor for one job. It hurts but i would just do all of them.
