question about boost
Old Mar 3, 2011 | 10:54 PM
oglejust's Avatar
Default question about boost
back n the day (last summer ) i could plug my wastegate and it would build boost very quick if i got on it in like say 3rd gear.. id have to get out of the throttle so it wouldnt build too much boost. stock turbo btw (wh1c). well i took the head off and had it milled .10 then put a .20 headgasket on, put a 3 piece manifold on and headstuds. along with 22.5* timing, it was at 18* b4 pulling the head. anyway i got it back together and hooked the wastegate up like it should b. drove it for a while without much boost, i then plugged the wastegate and i couldnt build boost like i should with it plugged. i thought maybe the wastegate was not working.. so i took the wastegate off and just wired the arm on the turbo in the direction i got the most boost. it builds boost as if it had a wastegate hooked up (30-35psi depending on the gear and my foot) but if it was like it used to b itd b making 50 or 60 (not that i want it to). anyway im just trying to figure out wat happened to make it lose the boost. i have 1 tiny leak at the oring at the mouth of the turbo.. i mean tiny! have tested for leaks and theres no other leaks. maybe the turbos goin south? it sat for a few months on my garage floor while the head was off.
Old Mar 4, 2011 | 04:04 AM
pukie370's Avatar
.020 head gasket why? shaving head does not change comp.
Old Mar 4, 2011 | 06:48 AM
BRE's Avatar
BRE
How do you figure?
Old Mar 4, 2011 | 10:11 AM
oglejust's Avatar
head was shaved to insure flatness and the .20 headgasket was more avaliable than the .10
Old Mar 4, 2011 | 11:16 AM
94 12valve's Avatar
what injector washers did you use?
Old Mar 6, 2011 | 05:14 PM
97CumminsDiesel's Avatar
... thats 100% not accurate advice
Old Mar 6, 2011 | 08:24 PM
justin c's Avatar
WHAT??? yes it does
anyways because the 20 over u may have lost some idk i lost 2psi with my 20 over and 10 off the head and lost another 3 when i went to fly cut pistons but dont forget i have 700cc of fuel so the impact might be more for u but i dont know much about this so thats just my 2 cents but u do loose compression when u go .010 over on a gasket from stock
yea thats a good point what one?
Old Mar 12, 2011 | 11:11 AM
oglejust's Avatar
uh whatever chris at sdx gave me..
Old Mar 12, 2011 | 02:33 PM
94 12valve's Avatar
were they the same thickness as your old ones? if so you should swap to a thinner washer
Old Mar 13, 2011 | 01:31 PM
oglejust's Avatar
think thatll make much difference? ill get some thin washers
