Price Quote - Request A Price This Forum is for Requesting Price Quotes - Upon Your New thread All Participating Vendors & Distributors Will Receive a Private Message Notifying them Of your Thread - You May Opt Out of this Option
97 12v big build alot of parts getting this week
Old Feb 20, 2011 | 04:55 PM
orangeracer's Avatar
Default 97 12v big build alot of parts getting this week
89-91 & 98.5-02 Dodge 24 Valve Cummins ATI Super Damper Harmonic Balancer 89-91 & 98.5-02 Dodge 24 Valve Cummins ATI Super Damper Harmonic Balancer
$436.00
89-98 5.9L Cummins Hamilton Diesel Big Stick 181/210 107 LSA Camshaft 89-98 5.9L Cummins Hamilton Diesel Big Stick 181/210 107 LSA Camshaft
- Bolt On Retainer No Retainer
- Zinc Additive Add bottle of ZDP Additive
$614.00
Hamilton Diesel 5.9L 12 Valve Cummins HD Springs & Billet Retainers/Keepers Hamilton Diesel 5.9L 12 Valve Cummins HD Springs & Billet Retainers/Keepers
- Spring Version HD12vs-1 Std
$549.00
89-98 Dodge 5.9L Cummins Diesel Hamilton Heavy Duty Push Rods 89-98 Dodge 5.9L Cummins Diesel Hamilton Heavy Duty Push Rods
$275.00
4K GSK RPM Governor Spring Kit 94-98 Dodge 12 Valve Cummins 4K GSK RPM Governor Spring Kit 94-98 Dodge 12 Valve Cummins
$115.00
AFC Spring Kit 94-98 Dodge 5.9L 12 Valve Cummins Diesel AFC Spring Kit 94-98 Dodge 5.9L 12 Valve Cummins Diesel
$35.00
94-98 Dodge 5.9L 12 Valve Cummins w/P7100 Timing Tool Kit 94-98 Dodge 5.9L 12 Valve Cummins w/P7100 Timing Tool Kit
$149.99
High Flow Laser Cut Delivery Valves, 94-98 Dodge 12V Cummins High Flow Laser Cut Delivery Valves, 94-98 Dodge 12V Cummins
- Additional Items No Delivery Valve Socket
$279.00
89-98 Dodge 5.9L 12 Valve Cummins Dual Valve Cover Breather Combo 89-98 Dodge 5.9L 12 Valve Cummins Dual Valve Cover Breather Combo
$179.00
94-98 Dodge 5.9L Cummins Diesel BD Fuel Shutdown Solenoid Kit 94-98 Dodge 5.9L Cummins Diesel BD Fuel Shutdown Solenoid Kit
$237.50
94-98 5.9L 12 Valve Cummins B Series Engine Rebuild Kit 94-98 5.9L 12 Valve Cummins B Series Engine Rebuild Kit
- Cam Bushing 89-97 Non-Encore Block
- Rod Bearings .010 Bearings
- Main Bearings Standard
- Bowl Style Large Bowl
- Piston Size Standard Bore
$749.99
89-98 Dodge 5.9L Cummins Diesel OEM Block Heater 89-98 Dodge 5.9L Cummins Diesel OEM Block Heater
$59.00
94-98 5.9L 6B Cummins Service/Shop Manual 94-98 5.9L 6B Cummins Service/Shop Manual
$129.00
5.9L 24 Valve Cummins 6BT Diesel Oil Pump 89-02 Cummins 5.9L 24 Valve Cummins 6BT Diesel Oil Pump 89-02 Cummins
$94.99
Dodge 89-98 12V Cummins Quickspool Pulse Exhaust Manifold Dodge 89-98 12V Cummins Quickspool Pulse Exhaust Manifold
$468.00
Sub-Total: $4,370.47
Reply to all
Forward
Old Feb 20, 2011 | 05:00 PM
mysterync's Avatar
Seems like someone went to a website , picked the "best" parts and decided it was a build.
For instance, the laser cut DV's , the AFC Kit and the cam are for the most part useless unless your doing something that no one else has ever done (doubt it)
Old Feb 20, 2011 | 05:26 PM
going to do twin turbos, looking for about 550hp and be reliable. I have a fully built suncoast trans for it. And going to port the head.
Old Feb 20, 2011 | 05:31 PM
mysterync's Avatar
Then you dont need the cam, Laser cuts or the AFC kit
Old Feb 20, 2011 | 08:24 PM
what do you suggest i do? For 550hp and good mpg
Old Feb 21, 2011 | 11:36 PM
big bad diesel 416's Avatar
Site Sponsor
can I ask where all this came from?
Old Feb 22, 2011 | 08:23 AM
pure diesel performance
ItsAChummins
May 15, 2015 05:02 PM
Tory4
For Sale
Feb 1, 2015 08:33 PM
