Garrett 38r
Old Feb 19, 2011 | 06:19 PM
shorty2tall's Avatar
Default Garrett 38r
How much power and psi is this turbo good for? It's on the truck im buying.
Old Feb 19, 2011 | 06:26 PM
powerstroke cowboy's Avatar
With a 1:00 A/R Exhaust housing 450-475hp With the 1:15 You can go a little higher (500 to 525HP) but you will get more smoke with that HP numbers.. But if you want to go higher yet you have to use a GT47 or GT55 to feed the 38R
As for boost they are good to 40 PSI, BUT your turbo will like you better if you keep it 34 and under
Old Feb 19, 2011 | 09:07 PM
joebob3093's Avatar
Moderator
Default Re: Garrett 38r
500 or so give or take. If you want more you can get a bigger single. You don't have to run compunds.
Sent from my DROIDX
Old Feb 20, 2011 | 09:42 AM
Default Garrett 38r
Ok cool thanks guys it's going to be awhile till I get to those numbers but at least I won't have to buy a turbo
Old Feb 20, 2011 | 09:45 AM
yep they are a good turbo. BB so you get good spool up.
Old Feb 20, 2011 | 09:53 AM
OceanDiesel's Avatar
Good proof is Brian Jelich, best pull was 992HP with a single turbo, and tweaking for 1,000+.
