Oil Leak Question
Old Feb 18, 2011 | 10:53 PM
jtrav2710's Avatar
Default Oil Leak Question
I noticed a small puddle of oil on the drive yesterday. My valley has puddles that were not there last time I checked. I have oil leaking down the rear, collecting on the oil pan. Turbo looks dry. I was about 2 qts low on oil, coolant was a bit low and the oil on the dipstick seemed a bit thin. Dripped off easily. I took it to the local repair shop and the guy said it was leaking around the water/fuel separator and said it would be a quick 50 dollar fix. Can oil leak from this area? I thought only fuel would? Any other ideas?
Old Feb 19, 2011 | 01:02 PM
Kyle_KleinSS's Avatar
Check the hpop fittings and the lines to the heads if its in the valley
Old Feb 20, 2011 | 03:33 PM
jtrav2710's Avatar
Default Thanks
Those are both areas that I will need to check next... I guess my main question is whether oil can leak from the water fuel separator??
cummins Pride
Sep 28, 2015 12:11 PM
Sootboyz89
Jun 28, 2015 02:31 PM
Gomerpile79
Apr 9, 2015 03:45 PM
pro graphic solutions
Feb 10, 2015 03:48 PM
ash23k
Dec 30, 2014 08:31 PM
