Diesel Swap 99 4X4 360 - 6BT
Old Feb 16, 2011 | 05:23 PM
renegadegoats101's Avatar
Default Diesel Swap 99 4X4 360 - 6BT
Hey guys,
I Have a 99 Dodge Ram 1500 4X4 gasser with 360 and i'd like to convert it to a 6BT. Any information is appreciated!
Old Feb 17, 2011 | 02:05 AM
u2slow's Avatar
I'd sell and buy a Cummins truck. JMHO.
I really hadn't considered selling my F350 at all... until a W250 for the right price showed up. Suddenly it was a no-brainer.
Old Feb 19, 2011 | 10:28 AM
well there are multiple conversions on here and im hoping one of those guys will respond, i've heard its not that difficult of a swap, i just want as much info as possible
Old Feb 19, 2011 | 03:15 PM
brianjbeach85's Avatar
Default dead horse
Not trying to be a pesimist, but would you really want a 6BT in a 1/2 ton? I would think there would need to be extensive mods done to the 1/2 ton such as suspension/drivetrain.. i couldnt imagine dodge would use a strong enough tranny/axle driveshaft to hold up to a diesel in a 1/2 ton.
Good Luck =) should get good mpg's in a 1/2 ton for sure
Old Feb 19, 2011 | 03:45 PM
EasternAggie's Avatar
Hmmmmm I would want a 6BT in a half ton
and I know a few other guys in the diesel performance world that have done the same thing.
Old Feb 20, 2011 | 10:39 AM
YoungDiesel27's Avatar
I just did the same conversion. I would recommend getting a donor truck and swap everything. Its not a hard swap but it took me a week to get it completed and another week to work the bugs out. good luck
Old Feb 20, 2011 | 12:01 PM
Dang not bad time at all
And ditto on the donor truck, it makes everything alot easier. I would recommend this route, and using the engine and tranny out of your donor truck. Im still running half ton axles, but befroe I do any major mods Im going to upgrade my rear axle. I have a set of 3/4 ton coil springs up front and front end is holding up well.
I know another guy with a 01 or 02 Dodge 1500 2wd reg cab that is running about 400 to the wheels through the stock rear axle.
Old Feb 21, 2011 | 12:02 PM
beerbellykelly's Avatar
just my personal-but the older trucks look soooo much better-the older the better,i run a 77 and 78 M880,s military pick ups-if you use the donor trans the job is pretty straight forward,you will find it easier if you have a good set of tools and equipment.
you know the old saying,measure it 5 times,draw it 3 times-make it once.
only problem i can see is your putting a lot more weight over the front end,i am using a different chassis and a wierd trans on my build,so i am putting as much weight over the rear end as i can-batteries,fuel,air tanks,propane,hydraulic pack etc.
gluck
Old Feb 21, 2011 | 01:55 PM
Agreed.
Do your research, be prepared, have what you need (most of it anyways) when you start, and itll go easier
Old Jul 16, 2012 | 09:34 PM
TBD's Avatar
TBD
I plan on starting my 12v 1/2 ton swap this week, just curious, how did you plumb your fuel system?
