Edge/Smarty Stack
Old Feb 14, 2011 | 10:06 PM
Farmboy 2.0's Avatar
Default Edge/Smarty Stack
So i bought a smarty we had today and I stacked it with my edge. And Im running my edge on three which is where I always have it with low end responsive on 1. And I have the smarty on 3 which is fuel+timing+boost and I set to torque management on stock because I have tons of fuel down low or should I change it, timing i bumped up to 2 and I turned to duration too 2 as well which I might turn down. So my question to you guys that have stacked them on vp trucks whats the best setting to set them on? What have you guys had the best luck with? Thanks Scott
Old Feb 14, 2011 | 10:30 PM
RAW's Avatar
RAW
I'm interested in this as well, as a Smarty is on the way!
Old Feb 14, 2011 | 10:35 PM
So far with it set up this way I never saw over 1200 degrees out on the maiden voyage!!! I cant tell you boost I was to busy looking for cops and watchen the street
Old Feb 15, 2011 | 03:42 PM
02cumminskid's Avatar
I run my comp on 4 and Smarty on 6. My torque is set on 6-wild, 2 Timing on stock injectors, and duration on 2-mild. I get a lil better milage set like this and it actually smokes less than on the default settings. I hit 40 psi of boost and if I stay in real long I've hit 1300 degrees.
Old Feb 15, 2011 | 03:50 PM
Yeah the thing I like about the smarty is odd numbers have added timing and then you can add more timing as well.
Old Feb 15, 2011 | 11:40 PM
mainman300's Avatar
crank it up see what happens.
Old Feb 16, 2011 | 09:25 AM
Haha Matt lets not just yet. I still need it evryday and dont need it all blown to chit
Old Feb 16, 2011 | 09:47 AM
From everything I have seen a Smarty/Edge stack on a VP truck hurts performance.
Old Feb 16, 2011 | 09:53 AM
01quadcab's Avatar
a lot of people believe they feel a difference, but put on dyno or take down the track and it's less.
Old Feb 16, 2011 | 10:35 AM
I took my Smarty off for a day and just ran the comp and there is a huge difference in power on the bottom end. I get 40 psi of boost with the Smarty and comp but only 35 with the comp by itself.
