convert srw to dually
Old Feb 14, 2011 | 09:47 AM
cthom8251's Avatar
Default convert srw to dually
I am doing research to find out what I need to change other than the bed to convert from srw to a dually
2006 Dodge Ram 3500 Laramie mega cab 5.9 diesel srw
Old Feb 18, 2011 | 07:35 PM
NoPlugs06CTD's Avatar
I just recently did this swap. If you can find someone who wants to make a trade the other way, then you just need tools and about 4 hours. You swap wheels/tires, bed and the rear end, and take off the front spacers from the dually. It is really easy to do.
If you cannot find someone to swap with, you can purchase the fenders ( DuallyFendersUSA.com ), then find a rear end from a salvage yard, then pick up a set of wheels. duallyfendersUSA sells a complete kit that uses rear spacers, they work excellently, I have seen several people just go to their kit and not mess with an axle swap, all bolt on.
I may have a pair of mega Cab fenders for sale soon.
NP
Old Feb 18, 2011 | 07:48 PM
cthom8251's Avatar
Why should I have to change the rear end? is there that much differance in the width? I would believe they would be close.
Old Feb 19, 2011 | 09:34 AM
Not close enough to just mount up a dually wheel, you will be into the springs with the wheel. The difference between the srw and drw is that the drw has a 2" extension per side to accomodate the depth of the dually wheel, you don't have to change rear ends, you can get a 2" spacer. If you go the spacer route, make sure it is hub centric.
NP
cummins.1.5.3.6.2.4
Sep 20, 2015 01:47 AM
Ward_59
May 12, 2015 04:39 AM
Brokencummins
13
Apr 20, 2015 01:05 PM
joseywales
Jan 16, 2015 08:44 AM
Machinist
Dec 5, 2014 01:06 AM
